8-98A Running Board Side Stainless Install
25 Jan 2017 13:00 #32351
Replied by Curt Schulze on topic 8-98A Running Board Side Stainless Install
Brad, you can buy parkerizing kits on eBay, the instructions are easy to follow.
Stainless steel blackening can be purchased at Caswell. This is even easier, no heat required.
- Brad Hoskins
- Thank you received: 11
25 Jan 2017 01:59 #32348
by Brad Hoskins
31 8-98 cabriolet
Replied by Brad Hoskins on topic 8-98A Running Board Side Stainless Install
How does one 'parkerize ' a modern fastener? And can you do it with stainless if one was 'nuts' enough to ? Any tips?
I've painted other fasteners on the car but that is messy and , as I'm sure you know, doesn't look quite right.
Brad
Brad
31 8-98 cabriolet
24 Jan 2017 13:31 #32334
Mark, your car takes 20. They are flat-sided bolts that slide down the channel. Use square nuts, all parkerized black.
My 31 and 32 are the same, but take fewer fasteners.
23 Jan 2017 22:40 #32328
by ilikescars
Replied by ilikescars on topic 8-98A Running Board Side Stainless Install
Prolly 10-15
- curtiss
- Premium Member
23 Jan 2017 22:34 #32327
by curtiss
Replied by curtiss on topic 8-98A Running Board Side Stainless Install
I will let you know, I have 2 more cars to do so I may have 10 or 15 extra clips. How many do you need?
23 Jan 2017 22:29 #32326
by ilikescars
I used the same clips, but instead of removing spring, I sanded off some of the top edge.
If you want to sell me the rest of your clips let me know. email is [email protected]
- curtiss
- Premium Member
23 Jan 2017 19:45 #32325
by curtiss
Thanks for the answers and pictures, Debby and I got them drilled and installed last night. I ended up having to use some Chrysler molding clips I picked up from Fasenal to slide into the outer strip. I had to cut off the spring end but they worked great.
Had to buy a box of 50 to get 10
Molding Clips
Chrysler: 1624705 6010093 Universal Moulding Fastener
Molding Clips
22 Jan 2017 18:52 #32315
Replied by johnmereness on topic 8-98A Running Board Side Stainless Install
On an 851 and 852 I believe the original nut is square - you may want to ask about what is original 31 /32.
- curtiss
- Premium Member
19 Jan 2017 23:21 #32312
by curtiss
Awesome, thanks for the pictures!
- Rlamb10769
- Senior Member
19 Jan 2017 17:16 - 19 Jan 2017 22:32 #32306
by Rlamb10769
I have attached a photo of my SS attachment, there are five of them..
Richard
Richard
Richard Lambert
ACD #3371
Replied by Rlamb10769 on topic 8-98A Running Board Side Stainless Install
Attachment not found
Richard
Richard
Richard Lambert
ACD #3371
Last edit: 19 Jan 2017 22:32 by Rlamb10769. Reason: Add photo
19 Jan 2017 14:33 #32304
by ilikescars
Curtiss: On my 36 Auburn, I ended up drilling extra holes near the ends of the trim to help hold the trim in tighter.
Then re-positioned the fasteners as needed. (No one noticed the difference in the amount of holes)
- curtiss
- Premium Member
18 Jan 2017 17:30 - 18 Jan 2017 17:30 #32294
by curtiss
8-98A Running Board Side Stainless Install was created by curtiss
I just received new running board side stainless and no holes were pre-drilled. I picked up some molding mount clips from Fastenal that look like they will work to secure the outer molding so not I need to figure out how many holes were typically drilled to mount these.
It appears in the last restoration the old holes were filled in so would one of you be able to look to see how many studs you have holding the running board stainless on?
Thanks!
Thanks!
Last edit: 18 Jan 2017 17:30 by curtiss.
