Differential seepage
20 Feb 2017 13:41 #32522
by ilikescars
Replied by ilikescars on topic Differential seepage
So far, no leakage after some driving. I don't think it makes sense to use split-washers on those bolts. More chance for oil to get past. I used copper crush washers, but that might be overkill. The Ultra Black RTV seems to hold everything in place. (Any RTV color would probably be fine, however, ordinary silicone is prolly not a good choice)
In answer to Curt: That fluid might be a bit too thick for a differential. Best for steering boxes that don't require as much mechanical movement in my opinion..
20 Feb 2017 06:43 #32520
Replied by johnmereness on topic Differential seepage
I think this a very important part: Made sure the surface where the bolts meet the "derby hat" flange was clean of paint.
10 Feb 2017 17:12 #32483
Replied by 1748 S on topic Differential seepage
Now drive this car to warm up the oil. Allow it to cool down. Do this a few times. Continue checking for any leakage. I bet you wont see any..
The following user(s) said Thank You: ilikescars
10 Feb 2017 14:53 #32482
by ilikescars
Update: I drained the diff and cleaned off all the mating surfaces & bolt holes with acetone. Used a small rat-tail brush to clean the threads, too. Made sure the surface where the bolts meet the "derby hat" flange was clean of paint. Then I used Ultra Black RTV to reassemble everything (no gasket was used) and smeared a small amount of RTV onto the bolt threads. Refilled the diff. So far, no leakage seen after 24 hours
06 Feb 2017 03:53 #32434
by ilikescars
I think you're correct, 1748. I just noticed today that another Auburn of mine has been sealed with a grey RTV and there is not a drop showing.
05 Feb 2017 17:26 #32431
I think the best way to seal any bolt threads from leaking is to first get it absolutely clean. Brakclean works well for me. the most any RTV will seal the threads. The key is a clean surface so the rtv can attach. My RTV choice is permatex ultra copper plus. It is heat and oil resistant. Find it everywhere. smell horrible but works great.
05 Feb 2017 12:33 #32430
Replied by Curt Schulze on topic Differential seepage
Has anyone tried Penrite in the diff? It is the best thing since sliced bread for the steering box.
05 Feb 2017 05:08 #32429
Replied by mikespeed35 on topic Differential seepage
All of the cover bolts need to be sealed in some way. I have tried to seal my cover multiple times with various methods and so far have been unsuccessful in doing so. I have no problem sealing engine oil pans but this cover eludes me.
04 Feb 2017 16:53 #32427
by ilikescars
Differential seepage was created by ilikescars
I noticed on an original, untouched Auburn dual ratio differential that there is some seepage that takes place around the tin cover. And the buildup of crud is substantial. Since the bolts that fasten this rear "derby hat" are subjected to gear oil, wouldn't it make sense to have copper crush washers on them?
