Reproduction Leaf Springs For A 1933 8-105
- memaerobilia
04 Aug 2017 16:57 #33370
by memaerobilia
Joe G.
hundreds of our early photos or planes, racecars, customs classics @ www.memaerobilia.com
Replied by memaerobilia on topic Reproduction Leaf Springs For A 1933 8-105
Here's a suggestion. We restored 38 pre-war cars and race cars. a fair number of projects were without springs or needed a whole new curvature or design to fit different weight engines into different rails and frames.
It was usually VERY inexpensive to have a new set of spring leaves fabricated, or leaves added. or simply giving the guy a full scale, rough dwg on cardboard., by the local, rural truck repair shop, down the road. Truckers are always breaking/needing oddball springs and shapes, and are usually pretty frugal.
Joe G.
- xjn001
03 Aug 2017 21:16 #33367
by xjn001
Replied by xjn001 on topic Reproduction Leaf Springs For A 1933 8-105
List of 5160 leaf spring steel from Admiral steel .
www.admiralsteel.com/
showing many sizes of leaf spring steel. Check if any sizes match your springs. This would be a start to fix any broken leafs. Just a thought,
03 Aug 2017 12:57 #33365
Replied by 1748 S on topic Reproduction Leaf Springs For A 1933 8-105
Have you called Doug Pray in Broken Arrow Oklahoma? They had complete front springs for my 37 Cord.
03 Aug 2017 11:39 #33363
Replied by Curt Schulze on topic Reproduction Leaf Springs For A 1933 8-105
I don't know about 1933 springs, but the springs Eaton makes for 34-36 Auburn are too thick and make the car set too high and they look ridiculous. I know of this occurrence happening to two different customers. Not only that, the spring covers don't fit..
- curtiss
02 Aug 2017 21:44 #33361
by curtiss
Replied by curtiss on topic Reproduction Leaf Springs For A 1933 8-105
YIKES, I am fairly crafty but not so sure about making my own springs Eaton said they would make a pair for around $600.
- xjn001
02 Aug 2017 21:39 #33360
by xjn001
Would you consider making your own springs? Using 5160 spring steel.
- curtiss
02 Aug 2017 20:35 #33359
by curtiss
Reproduction Leaf Springs For A 1933 8-105 was created by curtiss
I have had a few leafs crack on our 1933 8-105 front springs so I am thinking the best bet would be to find some reproduction Leaf Springs. I cheeked locally and they will not make a set so I checked with Eaton and they said they said the originals were 10 leaf but they can only reproduce them in 8 leaf.
Do you know of any other reproduction spring sources?
