Best Way To Pull An Engine 1933
  • mikespeed35
27 Dec 2017 04:44 #33956 by mikespeed35
Replied by mikespeed35 on topic Best Way To Pull An Engine 1933
What would we be damaging without a good woman to keep us out of trouble. My wife has helped we pull and install several engines over the years. Thanks for the video.
  • auburnandyscar
27 Dec 2017 03:32 #33953 by auburnandyscar
Replied by auburnandyscar on topic Best Way To Pull An Engine 1933
Thanks so much for posting this. New ACD members will enjoy seeing how the cars go together, and that one can be repaired without having to go to a restoration shop/ specialist.
Check out my build at:
www.1932auburnsedan.com
  • Jonathan Richards
26 Dec 2017 02:40 #33947 by Jonathan Richards
Replied by Jonathan Richards on topic Best Way To Pull An Engine 1933
Great video and audio, Curtiss. Thanks for posting for all to see. Merry Christmas and Happy New Year.
The following user(s) said Thank You: auburnandyscar
  • curtiss
  • Premium Forum User
25 Dec 2017 21:35 - 25 Dec 2017 21:37 #33946 by curtiss
Replied by curtiss on topic Best Way To Pull An Engine 1933
Thanks for all of the advice, we took everything apart and pulled the engine this weekend. The most challenging part was getting the clutch rod and peddles to come off.
We made a short video of the process we followed in case someone in the future is interested in watching.
Click here to watch Engine Removal Video
Last edit: 25 Dec 2017 21:37 by curtiss.
  • Curt Schulze
24 Dec 2017 12:33 #33931 by Curt Schulze
Replied by Curt Schulze on topic Best Way To Pull An Engine 1933
Andy, your ALF 12 must be a bit different than my 8. I had no trouble once the right rear engine mount was removed. The clutch adjuster and pedal came right off the shaft. The tranny tower and free wheeling shifter need to be removed. I find it is much easier to install the clutch and transmission out o f the car. The brake pedal is on the clutch pedal is off . Don't forget the front splash pan goes in before the engine is set.
  • auburnandyscar
24 Dec 2017 00:34 #33924 by auburnandyscar
Clutch pedal linkage is the "suck" to remove, no easy way to circumvent that,plan accordingly
  • Neal Ziff
21 Dec 2017 15:13 #33895 by Neal Ziff
Replied by Neal Ziff on topic Best Way To Pull An Engine 1933
I pulled the engine in my 8-95 using the same guidance you have been receiving here. Look back at my topic Time to Rebuild dating back to 12/2014. I removed the tranny separately first. Using a load leveler is a must. There are photos and great advice. It was a very rewarding challenge. Good luck.
Neal
_________________
1930 8-95 Cabriolet
  • Curt Schulze
21 Dec 2017 12:38 #33894 by Curt Schulze
Yes, take all od the ancillaries off the engine. I R&R'd my 31 with the trans and free wheeling attached. Pull the right rear engine mount off the
frame and remove the clutch pedal. A helper is a real plus.
  • mikespeed35
21 Dec 2017 05:37 #33893 by mikespeed35
I take all the heavy stuff of the engine, exhaust and intake manifold, gen., starter, and I don't try and take the trans. with the engine. I made a head plate that I bolt to the cyl. head bolts and lift from that point. I'm sure there are many other opinions on how to do it. You have to pick the one you thing will work for you.
  • curtiss
21 Dec 2017 04:12 #33890 by curtiss
Best Way To Pull An Engine 1933 was created by curtiss
Looks like I will need to pull the engine in our 1933 so I am looking for guidance from those who have done it before.
- How much does the engine weigh, want to make sure I have a strong enough lift?
- I assume remove the hood half's, radiator and grill is easiest?
- Should the engine and trans come out together or should the trans come out first and pull the engine ? It looks like leaving the transmission in may not be a good option.
- What are the best lifting points?
Thanks for any guidance!
