1936 Cabriolet Operation Manual
  • Curt Schulze
03 Mar 2018 12:41 #34245 by Curt Schulze
Replied by Curt Schulze on topic 1936 Cabriolet starting
Ken, I sent you a PM . with my phone number. I can help you with your technical questions.
  • mikespeed35
03 Mar 2018 05:15 #34244 by mikespeed35
Replied by mikespeed35 on topic 1936 Cabriolet starting
You can obtain a manual from the Auburn Cord Duesenberg Museum. The switch on the right is probably a electric fuel pump. Trace the wires and see where they go.
  • ilikescars
03 Mar 2018 01:57 #34242 by ilikescars
Replied by ilikescars on topic 1936 Cabriolet starting
The Startix box is mounted on the side of your engine. I assume you pushed the button on the side of that box to start you car.
That button is an override, in case the Startix selonoid gets stuck.
  • ilikescars
03 Mar 2018 01:49 #34241 by ilikescars
The STX switch (pictured on the left) is your starting switch. That toggle switch under the dash is not factory. Maybe it works your heater?
  • kenswheels
  • Senior Forum User
02 Mar 2018 23:21 - 02 Mar 2018 23:31 #34240 by kenswheels
Replied by kenswheels on topic 1936 Cabriolet starting
Is it one of these??
Last edit: 02 Mar 2018 23:31 by kenswheels. Reason: Shrink pic
  • ilikescars
02 Mar 2018 20:40 #34239 by ilikescars
There should be a toggle switch on the steering column, right side. Push the lever up to engage the fuel pump (if you have an electric pump)
Then click the lever down to engage the starter. As soon as the engine starts up, switch the lever back to the up position and that's all you have to do.
  • kenswheels
  • Senior Forum User
02 Mar 2018 19:22 #34238 by kenswheels
1936 Cabriolet Operation Manual was created by kenswheels
Hello again guys. Well the weather is finally starting to clear and it's time to use my new 1936 852 Cabriolet. As this is my first time owning a pre-war car, I'd like to know if there is any type of manual I can buy/download to help me operate the different systems. Starting with starting! Right now we need to lift the passenger side cowl and push a start button on the engine. Not convenient! Is there a proper way? This is where the manual would come in handy! Thanks in advance!
