- Thank you received: 18
Recommendation on Tires (Firestone vs Lester) 600/650-17???
- yorkgulch
- Premium Member
20 Mar 2018 20:57 #34347
by yorkgulch
Auburn 851
Replied by yorkgulch on topic Recommendation on Tires (Firestone vs Lester) 600/650-17???
There is a code on the tire that will tell you how old they are. If they are pre 2000 you may only get the year. You can get the code key online.
Auburn 851
- curtiss
- Premium Member
20 Mar 2018 19:08 - 20 Mar 2018 19:09 #34346
by curtiss
Recommendation on Tires (Firestone vs Lester) 600/650-17??? was created by curtiss
OK, now to my next decision
Our car has Lesters on it now and if I go back with Lesters I could get away with only swapping 4 tires but if I change to Firestones I would have to change all 6 tires to have them match. I have no idea how old the current tires are, that is why I am changing them out so if I ever had to use a spare I may not trust it much.
I am only familiar with the Lesters because they came with the car so I am looking for thoughts on pros and cons of the Lester and Firestones. I did notice the Lesters are 6 ply vs Firestone 4 ply but not sure what difference that will make.
I do like the more aggressive pattern on the Firestone but not sure which is more correct for the period as we will be showing it some.
Last edit: 20 Mar 2018 19:09 by curtiss.
