Gary I don't understand your question. If your failure resulted in the spring end and the brake backing plate being ground down then the anger bolt didn't fail, the car lost a wheel.
Regardless you should have the safety lops installed just in case.
- RubyDS
- Thank you received: 10
- RubyDS
- RubyDS
- RubyDS
- RubyDS
- RubyDS
- RubyDS
- RubyDS
- RubyDS
For the Soccer it's not my thing............
- Jonathan Richards
- Thank you received: 24
- RubyDS
- RubyDS
- RubyDS
- RubyDS
- RubyDS
Mine worked out with the following dimensions. Outside diameter 2.5" Inside diameter 2.125" Width 0.5"
- Thomas Wilcock
- Thank you received: 8
Tom
- RubyDS
I have cone 13889 and have ordered 4 cup 13830 availlable next week,many thanks
- Thomas Wilcock
Tom
M28241 / 1R2424 ......... is the needle bearing assembly
138890 .............................. is the taper roller cup
13830 ................................. is the taper roller bearing cone
The outside diameter of the bearing is 2 1/2" which fits inside the outer bearing block.
I can't remember the shaft size of the suspension arm
Any bearing company should be able to readily supply these parts.
- RubyDS
bearing Timken 13890
- John Meredith
- Thank you received: 18
- RubyDS
the price. They were $280. each. I also bought the 4 bearing that fit these races from a different supplier (old car bearing co.) in
North Carolina. I think they were $35.00 each. I purchased the double row races from Baystate Bearing co., 138 Reed Ave.,
West Hartford, Ct. 06110 phone number (860) 953-0055. Hope this helps....Cliff
- RubyDS
- RubyDS
- RubyDS
