810 gas pedal
- wcoye
10 Jun 2017 00:46 #33136
by wcoye
Bill Coye
Westchester 2240A
Brag line: Winner of the
Replied by wcoye on topic 810 gas pedal
Thanks to all for gas pedal mounting info. Sometimes knowing how to do something leads to other problems. I wanted to remove the front carpet and padding because sometime in it's life it was left outside, and she must have gotten and stayed real wet. The carpet just shredded as I cleaned it. Oh well it's time to spend more money and search for new carpet.
Bill Coye
Westchester 2240A
09 Jun 2017 11:00 #33133
Replied by Curt Schulze on topic 810 gas pedal
Ya, that is the same as 34-36 Auburn. And there is one at the top for the throttle rod. I have a couple of new ones if some one needs one.
09 Jun 2017 00:09 #33129
Replied by 1748 S on topic 810 gas pedal
I believe they are the same but not an expert. As alreay posted, these just ride on 2 ball studs.the steel ball stud is pressed up into the back of the rubber peddle. Once you get it off use some lube to ease the installation.
08 Jun 2017 23:57 #33128
Are Auburn & Cord Gas Pedals the same?
- George van Nostrand
- Thank you received: 35
08 Jun 2017 21:24 #33126
by George van Nostrand
Replied by George van Nostrand on topic 810 gas pedal
The gas pedal is mounted on two ball studs. Just pry it up gently- should remove it.
- wcoye
08 Jun 2017 20:55 #33125
by wcoye
Bill Coye
Westchester 2240A
810 gas pedal was created by wcoye
Hi, I am trying to remove the front carpet from my car. The gas pedal seems to be attached through the carpet but I can't see any method of attachment. Any
Any ideas?
Any ideas?
Bill Coye
Westchester 2240A
