Cord 810 motor oil
26 Jun 2017 04:10 - 26 Jun 2017 04:11 #33199
Replied by johnmereness on topic Cord 810 motor oil
www.classiccarmotoroil.com/
A lot of engineering has gone into this product.
www.classiccarmotoroil.com/articles.html
Last edit: 26 Jun 2017 04:11 by johnmereness.
- Tim Gilmartin
- Thank you received: 57
18 Jun 2017 21:06 #33175
by Tim Gilmartin
Replied by Tim Gilmartin on topic Cord 810 motor oil
Yes, I meant non-detergent oil.
18 Jun 2017 13:35 #33170
Replied by Curt Schulze on topic Cord 810 motor oil
Mike, I think Tim forgot to put the 'NON' in front of the detergent.
16 Jun 2017 21:25 #33166
Unfortunately the pages above loaded out of order. If anyone would like the original Skinned Knuckles version , send me an email
[email protected] and I'll get it to you.
Cheers
Cheers
16 Jun 2017 19:39 #33165
Replied by mikespeed35 on topic Cord 810 motor oil
Tim, how does detergent oil cause sludge to form, or did you misspeak.
16 Jun 2017 19:39 #33164
- kazmieth
16 Jun 2017 17:17 #33163
by kazmieth
Replied by kazmieth on topic Cord 810 motor oil
Thank you all for your help and info. This is more than I'd hoped for.
- Tim Gilmartin
16 Jun 2017 15:46 #33162
by Tim Gilmartin
I have been using 30W, non-detergent oil in my Cord 810 for over 15,000 miles now. I faithfully change the oil every thousand miles. Works fine, running a long time.
I agree with Curt. Detergent oil will cause sludge to form.
14 Jun 2017 11:55 #33150
13 Jun 2017 23:54 #33147
by uconn_1965
Replied by uconn_1965 on topic Cord 810 motor oil
I would stongly recommend 30W NON-DETERGENT oil. With the original system of the Cord with-out an external oil filter,
you want any sludge to accumulate at the bottom of the oil pan. and not be circulated thru the engine with detergent oil additives.
The following user(s) said Thank You: kazmieth
13 Jun 2017 18:24 #33145
Replied by 1748 S on topic Cord 810 motor oil
Good question with many correct and not so correct answers.I believe most agree with a single grade oil and choose a 30 wt. As for running what brand or natural or synthetic is once again another good question. I recall our engines do not have crankshaft seals because the case runs under a very slight vacuum. That copper line running from the oil fill spout up under the air filter gets vacuum from the air being drawn in thru the carb. The camshaft does have seals on both ends of it similar to a crank main seal design.
- kazmieth
13 Jun 2017 16:54 #33144
by kazmieth
Cord 810 motor oil was created by kazmieth
I'm doing my first oil change on my cord 810 since I purchased it in 2015, (Haven't driven it much). Any recommendations on the best oil to use?
