Caveat Cord 810/812 Owners
17 Sep 2017 16:39 #33578
Replied by 1748 S on topic Caveat Cord 810/812 Owners
Nope.. Not yet but I sure will look into this. My engine is still apart so it will be simple to check it out. I may even take and post pics of this.
- Jonathan Richards
- Thank you received: 24
17 Sep 2017 15:05 #33577
by Jonathan Richards
Caveat Cord 810/812 Owners was created by Jonathan Richards
If you experience sudden ignition failure with non-turning of rotor and distributor shaft check the connector at upper end of the intermediate shaft which runs from the gear at cam up to distributor shaft lower end. A screw is employed to affix this collar to the tapered shaft. Mine loosened and caused an immediate shut down of engine. Has anyone else experienced this problem in the past ???
