Finished Clutch
21 Sep 2017 00:27 #33592
Replied by 1748 S on topic Finished Clutch
Thanks Terry for the pics and dimensions. They sure will help insure my clutch is set correctly.
- Elite Member
- Thank you received: 301
20 Sep 2017 10:02 #33588
Replied by Terry Cockerell on topic Finished Clutch
Attached is the diagram I used to set the pressure plate fingers. I set the flywheel, clutch and pressure plate up in my lather and used a dial indicator to adjust the screws for uniform readings. Good luck.
20 Sep 2017 02:41 #33587
bearing pics
- Elite Member
20 Sep 2017 02:02 #33586
The $43 quoted for the spigot shaft bearing seems steep. Mine cost around $10 Aust
The round headed screws in the pressure plate fingers look the same as mine and probably came from a Ford.
The key is having them adjusted at the correct height and all equal.
Towards smooth gear changes, money well spent.
I have a diagram for setting the fingers correctly , I will dig it out and add it to the posting. Your screws look a bit too high.
19 Sep 2017 20:10 - 19 Sep 2017 22:52 #33582
more pics
Last edit: 19 Sep 2017 22:52 by 1748 S.
19 Sep 2017 20:08 #33581
Finished Clutch was created by 1748 S
