Steering Wheel Removal
25 Mar 2018 22:02 #34381
Replied by Terry Cockerell on topic Steering Wheel Removal
John, I made up a simple puller using plywood. There are two layers at the bottom end, each is cut in half to fit around the steering column then set at right angles to each other and fixed together. At the top end is a single piece of plywood with a spacer to put the load onto the column shaft and not damage the thread. It is all held together with threaded rods. I gradually tightened the the nuts at the top and the wheel came off without any damage.
- John Meredith
- Thank you received: 18
25 Mar 2018 18:21 #34379
by John Meredith
Steering Wheel Removal was created by John Meredith
What is the correct way to remove the steering wheel without damaging it?
