Model A Duesenberg Engine Gasket numbers
26 Jul 2017 04:17 #33331
Replied by mikespeed35 on topic Model A Duesenberg Engine Gasket numbers
1922-27 Duesenberg Head gasket Fitz. 493, McCord A-134.
The following user(s) said Thank You: hessacres
- hessacres
25 Jul 2017 21:44 #33328
by hessacres
Replied by hessacres on topic Model A Duesenberg Engine Gasket numbers
Any one have a McCord or Fritzgerald catalog?
- Dave Henderson
23 Jul 2017 21:26 #33316
by Dave Henderson
Replied by Dave Henderson on topic Model A Duesenberg Engine Gasket numbers
I don't know how the face got in there, should indicate that the crankshaft oil line plug uses 8.
- Dave Henderson
23 Jul 2017 21:23 #33315
by Dave Henderson
402 is correct for the head gasket. Others given in a 1940 Victor catalog are; esxhaust manifold 8298 (uses 2), exhaust pipe flange 6044, crankshaft oil line plug 2068 (uses , and crankcase oil line plug 2101.
They replaced part no's A-134, A-525, A-3002, `1423, ans A-121, respectively.
- hessacres
20 Jul 2017 01:05 - 22 Jul 2017 22:26 #33305
by hessacres
Model A Duesenberg Engine Gasket numbers was created by hessacres
Anyone have a reference book that can help me determine the Victor, McCord,, Fitzgerald (or any others) gasket part numbers for Model A Duesenberg Engine. A man came up to me at a car show and offered to check his stash of old gaskets if I knew the part number. I believe the Victor head gasket is 402.
Or if you have a original gasket that you know belongs to a A Duesenberg a photograph would also be helpful.
Last edit: 22 Jul 2017 22:26 by hessacres. Reason: more information.
