Restoring of Auburn Speedster Gauges
- Bobavet
- Junior Member
26 Apr 2013 02:58 #25080
by Bobavet
Robert Diepenbrock
Chandler, Arizona
Restoring of Auburn Speedster Gauges was created by Bobavet
Gents,
I recently purchased a 1936 852 Boat Tail Speedster. While most of the original dashboard gauges function, a few do not. I'm seeking advice and/or an expert who can restore the following:
Engine stats gauge (left gauge): Oil Pressure and Temperature function, the Amps and Gas Level do not. The Gas Level may be a faulty sender in the tank? Speedometer: Speed and main Odometer function the lower "trip" Odometer does not. The Oil Warning Light does not function (may be as simple as a burnt-out bulb). Auburn-Crosley Radio Dial & Knobs: Needle on Dial rotates when right "tuning" knob is turned. Left On-Off Volume knob appears to be non-functional. Clock: Non-functional. Auburn-Crosley Radio Box: Mounted vertically under the dash to the right of the Auburn Heater. Appears to be non-functional.
Any assistance would be appreciated.
Robert Diepenbrock
Chandler, Arizona
