- Thank you received: 12
Gear lube recommendation?
- Justin Kerns
08 Oct 2024 13:10 #48830
by Justin Kerns
Justin
1932 Auburn 12-160A Sedan
1933 Auburn 12-161A Sedan
Replied by Justin Kerns on topic Gear lube recommendation?
Justin
The following user(s) said Thank You: C.R.D., Joel
- Joel
Topic Author
05 Oct 2024 06:23 #48827
by Joel
Gear lube recommendation? was created by Joel
Hi, all of the lubricants listed in the factory service bulletins are obsolete. For a 33 Auburn, what would be the right lube for the transmission, freewheeling, and dual ratio rear end?
Thanks, Joel
Thanks, Joel
