1930 Auburn Master Brake Cylinder Leak
  • Alan Cutler
  • Forum Member
27 Jan 2025 21:53 - 27 Jan 2025 21:54 #49100 by Alan Cutler
Replied by Alan Cutler on topic 1930 Auburn Master Brake Cylinder Leak
Last edit: 27 Jan 2025 21:54 by Alan Cutler.
  • 1748 S
  • Platinum Forum User
27 Jan 2025 21:53 #49099 by 1748 S
Replied by 1748 S on topic 1930 Auburn Master Brake Cylinder Leak
The following user(s) said Thank You: Alan Cutler
  • Alan Cutler
  • Forum Member
27 Jan 2025 21:47 - 27 Jan 2025 21:51 #49098 by Alan Cutler
Last edit: 27 Jan 2025 21:51 by Alan Cutler.
  • Alan Cutler
  • Forum Member
27 Dec 2024 17:42 #49011 by Alan Cutler
The following user(s) said Thank You: 1748 S, Joel
  • mikespeed35
27 Dec 2024 05:03 #49006 by mikespeed35
Replied by mikespeed35 on topic 1930 Auburn Master Brake Cylinder Leak
  • Alan Cutler
  • Forum Member
25 Dec 2024 23:28 #49003 by Alan Cutler
  • mikespeed35
25 Dec 2024 23:27 #49002 by mikespeed35
  • Alan Cutler
  • Forum Member
25 Dec 2024 23:27 #49001 by Alan Cutler
  • mikespeed35
25 Dec 2024 23:24 #49000 by mikespeed35
The following user(s) said Thank You: 1748 S, Alan Cutler
  • 1748 S
24 Dec 2024 21:57 #48999 by 1748 S
  • Alan Cutler
  • Forum Member
24 Dec 2024 20:02 - 24 Dec 2024 20:08 #48998 by Alan Cutler
1930 Auburn Master Brake Cylinder Leak was created by Alan Cutler
Hello, I noticed a small drip a few months ago of Dot 5. It's now become a large drip, leaking out all of the reservoir fluid in about 2 days.
I wiped all the lines and the housing. Added new Dot 5, enough to cover the bottom of the tank. Within minutes, the leak appeared to be coming from the seam between the piston and the distribution housing.
Any insight would be appreciated.
Last edit: 24 Dec 2024 20:08 by Alan Cutler.
