AC 855228 Fuel Pump Diaphragm Leak
  • pete kelly
19 Feb 2025 02:24 #49169 by pete kelly
Replied by pete kelly on topic AC 855228 Fuel Pump Diaphragm Leak
  • Alan Cutler
  • Forum Member
16 Feb 2025 23:31 #49168 by Alan Cutler
Replied by Alan Cutler on topic AC 855228 Fuel Pump Diaphragm Leak
The following user(s) said Thank You: Joel
  • Alan Cutler
  • Forum Member
11 Feb 2025 16:28 #49155 by Alan Cutler
  • mikespeed35
  • Away
11 Feb 2025 04:54 #49152 by mikespeed35
Replied by mikespeed35 on topic AC 855228 Fuel Pump Diaphragm Leak
  • Alan Cutler
  • Forum Member
02 Feb 2025 16:54 #49131 by Alan Cutler
02 Feb 2025 02:28 #49130 by Joel
Replied by Joel on topic AC 855228 Fuel Pump Diaphragm Leak
Joel Nystrom
The following user(s) said Thank You: 1748 S, Alan Cutler
  • pwrightII
  • Senior Forum User
01 Feb 2025 11:33 #49127 by pwrightII
Replied by pwrightII on topic AC 855228 Fuel Pump Diaphragm Leak
The following user(s) said Thank You: Alan Cutler
  • Alan Cutler
  • Forum Member
29 Jan 2025 17:18 #49124 by Alan Cutler
  • Pat Leahy
29 Jan 2025 02:16 #49120 by Pat Leahy
Replied by Pat Leahy on topic AC 855228 Fuel Pump Diaphragm Leak
Pat Leahy
  • Alan Cutler
  • Forum Member
28 Jan 2025 17:41 #49119 by Alan Cutler
  • Alan Cutler
  • Forum Member
28 Jan 2025 17:38 - 28 Jan 2025 17:39 #49118 by Alan Cutler
Last edit: 28 Jan 2025 17:39 by Alan Cutler.
  • Rileypu29
  • Senior Forum User
28 Jan 2025 16:49 #49115 by Rileypu29
Replied by Rileypu29 on topic AC 855228 Fuel Pump Diaphragm Leak
Bill Kastanis
  • pete kelly
28 Jan 2025 14:28 - 28 Jan 2025 14:30 #49110 by pete kelly
Last edit: 28 Jan 2025 14:30 by pete kelly.
  • Alan Cutler
  • Forum Member
28 Jan 2025 14:14 #49109 by Alan Cutler
  • pete kelly
28 Jan 2025 03:42 #49105 by pete kelly
  • Alan Cutler
  • Forum Member
27 Jan 2025 22:24 #49104 by Alan Cutler
AC 855228 Fuel Pump Diaphragm Leak was created by Alan Cutler
So, as I was repairing the Master Cylinder leak, see previous thread, I noticed the mechanical fuel pump had drops of fuel on the bottom of the mounting. After the repair of the Master Brake Cylinder, I took her out for a test. Before heading out, I checked the fuel pump, which was leaking severely from the bottom of the arm housing.
Randy saw this pump at the CCCA Grand in Huntington Beach last year and said it was not the correct pump, and I quote, "You have no chance to locate the correct one." So, I need to rebuild this one. Does anyone have leads to start to search for a rebuild kit?
Thank you in advance.
