- WinAuBurn
- WinAuBurn
- WinAuBurn
You really won't like it if you forget it. Pull the choke out all the way , as soon as it fires push it in all the way.
- WinAuBurn
- WinAuBurn
- WinAuBurn
- WinAuBurn
Friends installed an overdrive on their 1938 Packard Convertible Sedan and experienced same/similar problems (in their case ate u-joints and had grinding/vibration) - they spent considerable time/money tracking down the issues and I took one look at car on lift and said by shortening the shaft via overdrive they changed the angles and if they put a small taper wedge in under the axle to spring mounts they may solve their problem (aka change angle) - it was a $25.00 issue and an afternoon of labor and they have a couple thousand miles CCCA touring since with no more issues. Sidenote: by changing angle too much you could then cause an oil starvation issue to pinion bearing.
- WinAuBurn
- WinAuBurn
- Brad Hoskins
- Thank you received: 11
I was thinking it might be 'cleaner' to put the unit inside the cross member but that would be tough given the width of the cross member.
Some photos from my static display.
The free wheel unit can be unbolted and that would save you about 5" . I would still leave it in place if at all possible .
I did email the ACD Company as per Randy's suggestion to see what they had in the way of NOS gear sets and I think the lowest they have is the 49:11
Anyway you do it, please post some details and photos of your overdrive conversion adventure here !
Brad
31 8-98 cabriolet
- WinAuBurn
After 1934 they were not used in Auburns. The dimension from the back of the 'X' member to the companion flange is 25"
- WinAuBurn
I think you are right. Since Bob and I will not get to see and work on the car until the 2nd week of April, I’m wondering if somebody has time to kindly measure the area from the rear of the X-frame to the rear axle including the freewheel – do we have at least 22” length (O/D is 20”), do we have 4” clearance from the driveshaft centerline to underbody? (O/D diameter is 6.5”).
I don’t see any reason why we could not connect the O/D directly to the rear axle. Also, what is the forum’s thought on the freewheel device? Is it needed, useful? We were not planning on using it.
Thanks, Colin & Bob
- Brad Hoskins
I don't think that the GV overdrive is going to be a problem from a HP perspective. If my read of the literature is correct, The GV at 1:.778 is still a higher (???? I always get confused on which way to call it!) final drive than factory two speed rear end at 1: .666 ( if my math is correct)
The bigger problem might be trying to get the overdrive in there! The free wheel unit already adds considerable length to the transmission and makes for a short driveshaft to start with . Getting drive shaft angles correct could be fun. Did GV say if you could save adding a second driveshaft by bolting up to the tranny or is that just too much hanging off the back?
Feel free to double check my 'speed' math as I was winging it. I used 2300 RPM as that is what Mike suggested and it seemed a pretty reasonable target for these long stroke engines.
BTW Just so you know, I don't think the drive shaft in your car is original to start with so don't get hung up on making changes My understanding is that the originals were a ball and trunnion design. They did not fair well if not perfectly maintained and there are no more parts available , which is why most are now converted to a Spicer joint like yours.
Brad
31 8-98 cabriolet
- WinAuBurn
Mike, please feel free to correct or comment on my summary.
So, the big concern with the GV and probably many overdrive solutions is the longer gearing can be a big step up for the engine to pull. In the GV case it is a ratio of 1:.778, Mike’s practical experience is this was too much for a 45HP car he ran. In addition, Mike had issues with the O/D kicking out downhill. Noted the O/D also does not operate in reverse. Mike’s older unit was 12V only.
We talked again about the Auburn 2-speed axle but it seems finding a ’32-’33 with controls, never mind ensuring it’s integrity is almost impossible. The ‘34+ 2-speed axles are out, too many complications with brakes etc.
On to my call with GV. They now provide a 6V setup for vintage cars like ours, the unit is inline about 20” long and 6 ½” diameter. They do come with standard 8” brackets but those would need to be modified for the X-frame. Also provided is a 2-wire switch for the unit but this could be changed as needed. Losses from the unit while engaged are claimed at 2HP and negligible to zero when disengaged – not too bad, but of course that is nearly 5% on a 45HP car. The O/D stays locked in during uphill or downhill (wonder if Mike’s unit was faulty). Does not operate in reverse gear and should not be operated below 15mph. Price as of writing is $2,995, delivery 3-7 days. Obviously we would need to fabricate new shafts (keep original) and the brackets for the install.
So is 98HP enough to pull the GV O/D in 3rd. Maybe? One thought here is that Auburn introduced the 2-speed axle as an optional upgrade for the ’32-’33 model years but this was still the same 98HP engine on the base car. That’s longer gearing. Also, the steeldraulic brakes remained on the car.
All options considered, we are willing to try the GV solution. Once we have delivery of the car we’ll check all the dimensions before proceeding with the plan. Will keep you informed.
Sorry for the long response, hope it was helpful. Thanks all. And thanks Mike.
- WinAuBurn
- Jonathan Richards
- Thank you received: 24
- Brad Hoskins
Don't get me started on this 'new' forum format and functionality ; it is terrible.!!!
I've had the same thing happen to me (timing out) several times.
I find if you log back in, go the the post you were replying to and , from the 'Action ' menu select 'Reply' again , you will find that you post is still there . As usual, you have to expand the dialog box to see anything.
I never use 'quick reply 'as the functionality is horrible. so I do not know if that works with 'quick reply' or not.
I'd love to see your post!!!!
Brad
31 8-98 cabriolet
CORDiallyMIke
- WinAuBurn
- Brad Hoskins
I was thinking of high speed sets for the three factory ratios that were available: in 31
49:11 = 4.45:1 Speed at @2300RPM = 46MPH
52:11 = 4.72:1
51:10 = 5.10:1 Speed at @2300RPM = 40 MPH
In 32 , they added another gear set which presumably would work in the 31 carrier as well (but the case numbers are different , so who knows!)
49:12 = 4.08:1 Speed @2300 RPM = 50 MPH
The 1932 two speed axles were 4.54: 1 low and 3:1 high according to the factory brochure
Speeds are my rough calculation based on 30' tires, as you can see, it is hardly worth it to invest in the gear set
Do you know anyone who did the Ford conversion and was happy with it? A 3.73 ratio would get you about 55MPH.
Gear Vendor overdrives look start at around $3000 and have 1:778 final ratio which isn't quite as good as the 2 speed if my math is right!!
That's all. I really should go work on my partially assembled static display!
31 8-98 cabriolet
- WinAuBurn
- Brad Hoskins
The 31's had three rear end ratios available but I think 90% of the cars had the low speed rear ends. I thought about having a new high speed gear set made but that isn't cheap either!
Of course my car seems stuck in static display mode and therefore goes just as fast with any of those options:(
Here's a link to an good AACA discussion on overdrives vs 2 speed v new ring and pinion.
forums.aaca.org/topic/300879-high-speed-...ents#comment-1674204
It involves Packards which always seems to lead to some very opinionated comments , unlike us laid back ACD people!
Nice car BTW!
31 8-98 cabriolet
- WinAuBurn
I do see an Auburn '35 2 speed axle for sale on the bay, but duly note Curt's comments not to go there with a '31.
All other thoughts welcome.
- Brad Hoskins
Another option would to do an overdrive conversion There are a number of posts over on the AACA forum on that issue. I'm not sure of how difficult it would be to to an Auburn.
With Auburn's open driveshaft , the conversion should only require a couple of new driveshafts .and should be easily reversible to put it back to stock if one wanted to go back to original.
Only issue might be the the X-member. getting in the way of mounting.
Anyone tried overdrive on the 31-33 Auburns?
Brad
31 8-98 cabriolet
- WinAuBurn
- WinAuBurn
Can a 2-speed differential be retrofitted to the '31 car or is this folly? Anybody done it?
- WinAuBurn
Thanks for your reply.
The shorter shift lever allows a hi low range selection, correct? I assume this is a hi lo drive option within the design of the transmission. (The car does not appear to have a Columbia 2 speed differential)
- WinAuBurn
