Turn Signals and Brake Lights
12 Jul 2018 21:10 #34963
Replied by Curt Schulze on topic Turn Signals and Brake Lights
No trick. The originals were hex , so you can put a wrench on it. The old ones will fail with DOT5 . I can supply a new one that has the hex and will not fail with silicone fluid.
- kenswheels
12 Jul 2018 20:30 #34962
by kenswheels
Replied by kenswheels on topic Turn Signals and Brake Lights
Little A, little B.
Checked the lights, they work.
Check the switch...Nothing.
Looks like I need a new one. Any trick to replacing it?
12 Jul 2018 20:15 #34961
Sure, if the wiring is good and the sockets and the bulb is good. I thought you wanted to check the switch.
- kenswheels
12 Jul 2018 20:03 #34960
by kenswheels
Just to cheat, if I connect the 2 studs shouldn't the brake lights come on?
12 Jul 2018 19:57 #34959
One side has a hot wire . Have someone step on the brake pedal , check the other side and see if there is power there.
- kenswheels
12 Jul 2018 19:31 #34958
by kenswheels
Hi Curt.
Found it!
Is there a way I can figure out if it's still working?
Found it!
12 Jul 2018 19:00 #34957
A brake booster did not come on your car from the factory. The brake light switch is on top of the brake junction block that is bolted to the LH frame rail near the cowl. If you need a brake light switch, I have new ones that are impervious to DOT5 and judge well.
- kenswheels
12 Jul 2018 15:47 #34956
by kenswheels
21 Jun 2018 04:39 #34794
Replied by mikespeed35 on topic Turn Signals and Brake Lights
I agree with Jim. Strange phenomenon with lights is usually ground problems.
20 Jun 2018 23:28 #34792
Replied by JIM.OBRIEN on topic Turn Signals and Brake Lights
Check your ground. You may have lost it.
20 Jun 2018 17:25 #34790
by pete kelly
Replied by pete kelly on topic Turn Signals and Brake Lights
Start with a check to see if the brake switch works then proceed to the turn signal switch wiring.
Good Luck
Good Luck
- kenswheels
20 Jun 2018 16:50 #34788
by kenswheels
Turn Signals and Brake Lights was created by kenswheels
Hello everyone.
Upon driving to a show this weekend, my followers noticed that I had no brake lights and when signaling, both sides flashed when signaling left or right.
Any suggestions where I should start looking?
