1931 Cabriolet rumble seat opening spring
26 Oct 2018 20:13 #35832
Replied by mikespeed35 on topic 1931 Cabriolet rumble seat opening spring
I'm going by L-29 Cord but if you remove the cushions you should see them.
26 Oct 2018 19:15 #35829
Replied by Curt Schulze on topic 1931 Cabriolet rumble seat opening spring
I would try the spring section of your local hardware store. Not a big box store.
- pwrightII
26 Oct 2018 14:04 #35828
by pwrightII
Replied by pwrightII on topic 1931 Cabriolet rumble seat opening spring
Thanks David and Mike. Do either of you know if the springs are available and from whom. Also, how do I access the location to replace them. Pete
26 Oct 2018 03:51 #35826
If you ever take the seat back cushion out, and open the lid with out it in place, the lid comes crashing open, Just a tip.
- DavidK
26 Oct 2018 01:50 #35825
by DavidK
Replied by DavidK on topic 1931 Cabriolet rumble seat opening spring
There were two springs ( part # G6-4676). They are attached to the lower hinges, one on each side,, of the rumble seat. Some people only run one spring because they are fairly strong.
- pwrightII
24 Oct 2018 16:13 #35817
by pwrightII
1931 Cabriolet rumble seat opening spring was created by pwrightII
When I turn the release for the rumble seat on my cabriolet, the rumble seat does not slightly open like I believe it should. I have to push it open from the inside. Was there a spring to force the edge of the rumble seat open (like a bit of a pop up) so the edge can be grabbed to open the seat completely. If so, where would it be mounted. Thanks, Pete Wright
