1st gear or reverse does not engage
  • JIM.OBRIEN
  • Premium Forum User
22 Nov 2024 02:06 #48891 by JIM.OBRIEN
Replied by JIM.OBRIEN on topic 1st gear or reverse does not engage
23 Oct 2024 05:19 #48843 by JLReus
Replied by JLReus on topic 1st gear or reverse does not engage
  • Terry Cockerell
  • Elite Forum User
15 Aug 2024 07:43 - 15 Aug 2024 07:58 #48742 by Terry Cockerell
Replied by Terry Cockerell on topic 1st gear or reverse does not engage
Last edit: 15 Aug 2024 07:58 by Terry Cockerell.
  • Tcheri
  • Senior Forum User
15 Aug 2024 07:33 #48741 by Tcheri
Replied by Tcheri on topic 1st gear or reverse does not engage
  • Terry Cockerell
  • Elite Forum User
15 Aug 2024 06:19 #48740 by Terry Cockerell
  • JIM.OBRIEN
14 Aug 2024 22:51 #48739 by JIM.OBRIEN
The following user(s) said Thank You: Tcheri
  • Tcheri
  • Senior Forum User
14 Aug 2024 13:11 #48738 by Tcheri
1st gear or reverse does not engage was created by Tcheri
 I left my 812 for probably a year without using it. When I started it up again, I immediately had problems shifting into 1st or reverse when I was stationary. Eventually it worked after a big push on the accelerator, but similar problems occurred when I was driving and the gears stopped changing. At the same time, my engine was running too lean. So I'm thinking of a leak in the vacuum circuit. What do you think? Where should I check first?
Thierry, Belgium
