- Thank you received: 28
Re: Autolite Coil
- ACD Club Member
28 Mar 2016 20:49 #30895
Re: Autolite Coil was created by 1748 S
Can anyone tell me the correct Autolite coil part number? I'm not sure I have the correct part but would like to know what is correct. I do have the coil that fits thru the firewall and connects to the ignition switch thru the cable. Also have the original ignition switch too.
- George van Nostrand
- ACD Club Member
29 Mar 2016 00:25 #30896
by George van Nostrand
Replied by George van Nostrand on topic Re: Autolite Coil
Gary, The original coil number is CE-420. It had a fixed bracket.
The service replacement coil number is CE-3224-JS. It uses a separate bracket.
Same coil fits many 8 cyl cars - Chrysler 8 36-42, Hudson 8 36-42, Studebaker 8 41-42 etc.
The IG-3224-JS is similar, but is used on six cylinder cars.
George.
George.
- ACD Club Member
29 Mar 2016 18:27 #30900
Replied by 1748 S on topic Re: Autolite Coil
Thanks for the information George. It appears I may not have an original coil. My bracket is not made as part of the coil. My numbers are different from what you posted too. But it does have the coil wire fitting that screws into the end and the other end is connected to the ignition switch if I remember correctly. I will post pics of what I have and the part numbers too.
- ACD Club Member
30 Mar 2016 03:31 #30901
Here are some pics of my coil.
- ACD Club Member
30 Mar 2016 03:31 #30902
1748 S wrote: Here are some pics of my coil.
- ACD Club Member
30 Mar 2016 03:32 #30903
Moderators: Joe Holderman
Time to create page: 0.097 seconds
