Rear View Mirror Pictures Needed
20 Dec 2018 12:18 #36177
Replied by Curt Schulze on topic Rear View Mirror Pictures Needed
I have mirror glass if you need one.
20 Dec 2018 03:58 #36175
by uconn_1965
Replied by uconn_1965 on topic Rear View Mirror Pictures Needed
Gary: Just be aware that modern mirror glass is not as thick as the original cord rear view mirror glass.
20 Dec 2018 03:06 #36174
Replied by 1748 S on topic Rear View Mirror Pictures Needed
Thanks Jim.. That helps in my search for a correct glass. Might just get a tracing and have one made locally. I have several glass shops able to cut and grind or bevel any glass.
- Premium Member
20 Dec 2018 01:59 #36171
Replied by JIM.OBRIEN on topic Rear View Mirror Pictures Needed
Gary,
The mount and pieces are correct. The mirror is wrong.
The phaeton is exactly the same.
- STEVEN.KUIPER
- Senior Member
- Thank you received: 17
19 Dec 2018 14:08 #36166
by STEVEN.KUIPER
Replied by STEVEN.KUIPER on topic Rear View Mirror Pictures Needed
what does the cord phaeton mount look like?
18 Dec 2018 00:26 #36154
The ball-stud looks the same as 35-36 speedster.
17 Dec 2018 23:50 - 17 Dec 2018 23:56 #36153
Thanks for the pics and information to what other cars used this mirror. Terry your pics here did not come thru but they did on my email here at home. This is the appearance of my mirror glass and bracket as found. The glass appears to be incorrect but the mount is correct..
Last edit: 17 Dec 2018 23:56 by 1748 S.
- Elite Member
- Thank you received: 301
17 Dec 2018 19:52 #36151
Replied by Terry Cockerell on topic Rear View Mirror Pictures Needed
I assumed this mirror was the same as that used in Auburns after riding in a supercharged Auburn phaeton recently.
The Cord has the mirror mounted on a short ball ended shaft which is fixed to the wooden trim strip between the windshields.
As previously mentioned Gary I took these pictures with the mirror in position.
17 Dec 2018 12:46 #36147
The 810-812 mirror glass & bracket is the same as 34-36 Auburn. I have them if you need one . I cannot tell you how they mount in an 810 - 812
16 Dec 2018 23:16 #36144
Rear View Mirror Pictures Needed was created by 1748 S
Can someone post pictures of an original rear view mirror glass sides and the mounting mechanics. Thanks...
