- Thank you received: 302
headlight issues 819
13 Feb 2019 20:50 #36635
Replied by Terry Cockerell on topic headlight issues 819
You could do both. Search the Forums for detailed information.
Purchasing the book from the Auburn Museum gives you an enormous amount of information that you will need on maintaining and understanding your Cord.
- [email protected]
13 Feb 2019 12:20 #36630
by [email protected]
Replied by [email protected] on topic headlight issues 819
Terry do I have to purchase this manual or is there any posts that cover the issue of the headlamps. Vin
- Lycoming288
13 Feb 2019 02:09 #36626
by Lycoming288
Replied by Lycoming288 on topic headlight issues 810
Turn front wheel inboard;
Inside the fender, loosen numerous hex bolts surrounding the headlight assembly bucket. Don't remove all of them yet.
If you're happy with the fit & finish of the (closed) headlamp covers, protect the paint/fender all around the opening seam with a couple layers of masking tape.
Remove the hex nuts all the way. The bucket will be removable from inside the fender.
These hex nuts when loosened allow adjustment of the headlamp cover to achieve a good fit.
When removing only the lens & retaining ring (while bucket's installed in the fender in the event of a simple bulb or reflector servicing), use extreme care to avoid dropping off the lens onto the bumper or ground.
Suggest several large towels placed on a stand below the headlamp covering the bumper while performing this risky op.
Good luck.
Cort
Good luck.
Cort
The following user(s) said Thank You: [email protected]
12 Feb 2019 20:51 #36625
The Cord Service Manual which is available from the Museum in Auburn covers this and a whole lot more.
- [email protected]
11 Feb 2019 12:49 - 13 Feb 2019 00:55 #36622
headlight issues 810 was created by [email protected]
I would like to piggyback on the headlight issue for the hideway headlights o n the 810. Does anyonne have a diagram that shows the removal process for the headlight cover. Thanks Vin
Last edit: 13 Feb 2019 00:55 by Joe Holderman.
