- Thank you received: 19
Bustle Trunk Seal
- Premium Member
14 Feb 2019 22:06 #36643
by balinwire
Replied by balinwire on topic Bustle Trunk Seal
Great link, what one looks like a good fit for Bustle trunk. also correct window felt channels and front hood felt pad.
stores.restorationspecialties.com/closed...t=bestselling&page=1
- Cordura
- Junior Member
14 Feb 2019 18:56 #36641
by Cordura
Replied by Cordura on topic Bustle Trunk Seal
wynlaidig, Call me 406 842 7655, I can probably find you the proper seal rubber from an after-market supplier. Peter Morgan
- wynlaidig
- Thank you received: 44
14 Feb 2019 12:53 #36640
by wynlaidig
Replied by wynlaidig on topic Bustle Trunk Seal
The 13mm dim on your Westchester is the standard 1/2" size that is used on the Cabr and Phaeton trucks as well. But that size is too small for the Bustle trunk on the Custom Beverly. It has to be more like 3/4" to work. The metal lip around the trunk is just too tall for a 1/2" seal.
- Elite Member
- Thank you received: 301
14 Feb 2019 08:00 #36639
14 Feb 2019 04:25 #36638
Replied by 1748 S on topic Bustle Trunk Seal
Thanks Terry. That helps me so much. I can find something with those dimensions for sure.
- Elite Member
14 Feb 2019 03:53 #36637
Replied by Terry Cockerell on topic Bustle Trunk Seal
The Westchester trunk seal is D shaped and measures 13 mm x 13 mm with a 6 mm hole in the middle. The flat base is pre-glued with a tear off strip.
Hope this helps.
Hope this helps.
- Elite Member
13 Feb 2019 20:48 #36634
I will check the dimensions of the D section used on my Westchester and let you know. I am sure there will be a supplier of an equivalent out there. I will ley you know later today ............................ I am in Australia.
Cheers,
Terry
Cheers,
Terry
- wynlaidig
13 Feb 2019 12:41 #36631
by wynlaidig
No he doesn't have any. He has the smaller half round for the open cars but it is too small for the bustle trunk. If it's the same hollow D profile but just larger I can find it somewhere. I just didn't know for sure what it was supposed to be. Just knew the smaller open car seal didn't fit.
- Elite Member
13 Feb 2019 08:31 #36629
Stan should have this at AC Parts in Kansas. I would assume it has the same cross section as used on Westchesters .................... a hollow D section with a pre-glued flat side.
- wynlaidig
13 Feb 2019 02:17 #36627
by wynlaidig
Bustle Trunk Seal was created by wynlaidig
Can someone show me what profile seal should be on the bustle trunk? There is nothing on my car, and i am not sure what seal to use, or how it mounts.
