Transmission Fluid and gage on pump
- Premium Member
- Elite Member
- Thank you received: 301
I would be interested in finding out about oil cooler modifications.
I am restoring mine to be a good reliable driver. I am located in Australia.
My email address is [email protected]
- rlwardne
- Senior Member
If you haven’t you should as there is no visual way to check it.
- rlwardne
- Senior Member
I did purchase the pump from the fellow on eBay mainly cause he only lives three hours away. Installed and test run on stands in second gear produced 15 psi at idle speed. Now to fix the leak on my filter housing. Pretty sure the fluid I’m running is more summer driving. Is the Gibbs yellow metal safe.? I haven’t looked
At their data.
- Cordura
- Junior Member
Gary Parsons.
- rlwardne
- Senior Member
- rlwardne
- Senior Member
- rlwardne
- Senior Member
Randy
- Premium Member
- rlwardne
- Senior Member
Out the output on the case. Replaced the spring and ball and decided to run some more never eeked a drop. So guessing the pump is pooped? Can I guy remove that pump while in the frame?
Thanks Jim!
- Premium Member
- rlwardne
- Senior Member
sucking from the case to the pump as I understand it.
Randy
- Premium Member
- rlwardne
- Senior Member
Thanks Randy
- Premium Member
As for the gauge it's very simple to add one in. you can pull the plug in the cap on the filter and tap a line for a pressure gage or put a pressure switch in there with a light on the dash or in the glove box.
- rlwardne
- Senior Member
In to check the health of the transmission pump?
