Duesebpnberg fuel pumps
- Va 33
- Junior Member
20 Mar 2014 18:19 #27223
by Va 33
Replied by Va 33 on topic J 408
. We found it, the engine does have its original crank...many thanksJoel wrote: The crankshaft number is on the side of the rearmost crank throw. On the attached picture, you can see the rear main bearing and the bellhousing at the right side of the picture. This is viewed from underneath with the oil pan off.
- Va 33
- Junior Member
11 Feb 2014 21:22 #26952
by Va 33
Replied by Va 33 on topic Crankshaft number
- Bob Roller
- Premium Member
11 Feb 2014 19:18 #26951
by Bob Roller
Bob Roller
Replied by Bob Roller on topic Crankshaft number
Try removing the crankcase vent and take a look and see if the number can be seen.You probably will have to roll the crankshaft by bumping the starter.
Bob Roller
Bob Roller
Bob Roller
- Joel
11 Feb 2014 17:50 #26949
by Joel
Replied by Joel on topic Duesebpnberg fuel pumps
- Va 33
- Junior Member
11 Feb 2014 14:53 #26946
by Va 33
Duesebpnberg fuel pumps was created by Va 33
We are restoring J408 my question is was a block or some type of pad between the auto pulse fuel pump mounting bracket and the frame? It appears to need more clearance between the pump manifold and the frame.
Also where is the crank shaft serial number located?
