Duesenberg spring wrapping
- Mike Dube
28 Mar 2014 14:51 #27293
by Mike Dube
8-100A
Replied by Mike Dube on topic Duesenberg spring wrapping
I lube the springs on the '32 every now and then. I can see spring covers being a good item to have on a regularly driven car.
8-100A
- Bob Roller
28 Mar 2014 12:47 #27292
by Bob Roller
Bob Roller
Replied by Bob Roller on topic spring covers
I don't recall seeing them on any "J" but I do recall requests to "spray the springs"on others. The other observations on covers make perfect sense to me.
Bob Roller
Bob Roller
Bob Roller
28 Mar 2014 02:23 #27291
Replied by mikespeed35 on topic Duesenberg spring wrapping
I would guess the biggest reason was to contain lub. on the springs.
- auburnandyscar
27 Mar 2014 21:30 #27287
by auburnandyscar
Check out my build at:
www.1932auburnsedan.com
Replied by auburnandyscar on topic Duesenberg spring wrapping
My guess is that the spring coverings did three things:
1) helped to quiet any 'squeaking' noise from the springs
2) prevented any 'rusty' water from dribbling down the sides of the nicely painted spring packs, staining/discoloring them.
3) prevent the rusty water from getting onto the tires. (when double sided WW's were common)
I have no idea as to how they could affect judging standards on your particular car.
- Va 33
27 Mar 2014 15:50 #27284
by Va 33
Replied by Va 33 on topic Spring covers
Thank you.....how do they effect judged shows?
27 Mar 2014 15:03 #27283
by RandyEma
Replied by RandyEma on topic Duesenberg spring wrapping
The Factory supplied no spring covers on there chassis.Owners through there coachbuilders may have added them.
- Va 33
27 Mar 2014 06:05 #27281
by Va 33
Duesenberg spring wrapping was created by Va 33
Were all cars supposed to have the spring wrapping I recently visited the Nedercutt Museum and some were and some were not, what is correct? And the purpose and method was what? Some appear to have used a vinyl material I assume leather would be correct, and did wrapping have metal eyelets not unlike old leather work boots?
