Model SJ Murphy Convertible Coupe I.D. sought
- Steve Derus
28 Sep 2018 03:09 #35528
by Steve Derus
Replied by Steve Derus on topic Model SJ Murphy Convertible Coupe I.D. sought
It appears that this car (and probably others) were returned to the factory for supercharger installation. I'm wondering if the factory also updated engine internals such as tubular rods etc. I'm not trying to cast any doubts on the provenance of this wonderful car just curious.
- HSS1929
- Senior Member
26 Sep 2018 17:41 #35517
by HSS1929
Replied by HSS1929 on topic Model SJ Murphy Convertible Coupe I.D. sought
Thanks Randy for the ID. More photos of the car here (which I was able to find knowing the engine / chassis numbers):
www.conceptcarz.com/profile/14892,13852/...enberg-model-sj.aspx
10 Sep 2018 15:15 #35388
by RandyEma
Replied by RandyEma on topic Model SJ Murphy Convertible Coupe I.D. sought
Painted wire wheels were standard. R
- jamesbartlett
10 Sep 2018 11:13 #35387
by jamesbartlett
'35 Auburn S/C Convert. Sedan
'32 Duesenberg D/C Phaeton
Replied by jamesbartlett on topic Model SJ Murphy Convertible Coupe I.D. sought
So if this car is original., does that mean that painted wire wheels were correct in some cases?
- Jonathan Richards
- Thank you received: 24
06 Sep 2018 18:02 #35362
by Jonathan Richards
Replied by Jonathan Richards on topic Model SJ Murphy Convertible Coupe I.D. sought
What an absolutely stunning original Duesenberg Model J. Thank you for posting this marvelous image. As folks are inclined to say " They are only original once." Magnificent!!!
05 Sep 2018 23:10 #35356
by RandyEma
It is J478 2496 Murphy Conv coupe
- HSS1929
- Senior Member
05 Sep 2018 22:37 - 05 Sep 2018 22:38 #35355
by HSS1929
Model SJ Murphy Convertible Coupe I.D. sought was created by HSS1929
Last edit: 05 Sep 2018 22:38 by HSS1929.
