Cord 812 Horn contact
- hportz
07 May 2011 00:56 #20024
by hportz
www.portzcordz.com (photos)
Replied by hportz on topic Horn
Lee, Send me your address & I'll send you a drawing of the stuff. Henry
- Lee Carr
06 Feb 2011 02:42 #19163
by Lee Carr
Cord 812 Horn contact was created by Lee Carr
I need help with the configuration of the original horn contact under the horn ring to connect the column wire to ground. Mine has been molested, modified and screwed up to not work. There is not enough left to see what it should be. Help.
