Ammeter short
09 Sep 2018 23:05 #35386
Replied by Curt Schulze on topic Ammeter short
The modern gas gauge fluid is not corrosive . The trick is get the stuff that doesn't turn clear.
09 Sep 2018 21:35 - 09 Sep 2018 21:36 #35385
Replied by mikespeed35 on topic Ammeter short
The amp meter is in the same cluster as the gas gauge. The gas gauge fluid is very corrosive and will rust anything inside the cluster. I vented my gas gauge outside the cluster to keep the amp. gauge from getting "crusty"
Last edit: 09 Sep 2018 21:36 by mikespeed35.
09 Sep 2018 18:48 - 09 Sep 2018 18:48 #35384
Replied by johnmereness on topic Ammeter short
I have adapted in other ammeters - last one was from a WWII Jeep - usually takes a little filing and handwork. And, be super careful regarding shorting. and that nothing dislocates when tightening the terminals.
Last edit: 09 Sep 2018 18:48 by johnmereness.
11 Jun 2018 11:37 #34758
by ilikescars
Ammeter short was created by ilikescars
Thought I'd share this experience with the clubmembers:
I recently installed a wiring loom on a 36 Auburn along with an ammeter in the dash. The ammeter looked a little crusty, but otherwise OK.
After running the car and shutting it off, I walked away for a moment. Upon returning to the car, I saw tons of smoke billowing from the wiring loom.
I immediately pulled the ground cable off the battery and the the smoke subsided. I discovered that the red wire coming off the Startix had burned it's insulation off. Looking at the ammeter, I guessed that the wire may have grounded on the body of the instrument cluster near the ammeter.
Maybe someone can add their thoughts to this problem. (Best to use a new ammeter?)
