Flywheel torque specs
  • 1748 S
  • Platinum Member
10 Nov 2018 18:33 #35934 by 1748 S
Replied by 1748 S on topic Flywheel torque specs
In my restoration I have "found" so many bolt threads that are fine threads where in normal engines of today they are coarse threads. I too found this out the hard way when I tried to "clean up" so threads in the block mounting holes for the motor mount plates. Its like measure twice... Cut once...
  • johnmereness
10 Nov 2018 17:30 #35933 by johnmereness
Replied by johnmereness on topic Flywheel torque specs
Take extra time to make sure it is all correct bolts, double check everything, and ... - I had to basically throw away what should have been a beautiful flywheel, clutch disk, and pressure plate that probably only had 10 to 15 minutes of driving on them because somehow junk hardware store bolts of wrong size got installed - unbelievable the damage to each in such a short period of time and just lucky that was extend of it :)
  • mikespeed35
09 Nov 2018 03:37 #35925 by mikespeed35
Replied by mikespeed35 on topic Flywheel torque specs
That's called torque till yield! I hang my head in shame, I have done that!
  • ilikescars
08 Nov 2018 15:22 #35924 by ilikescars
Replied by ilikescars on topic Flywheel torque specs
Or as a friend said: Tighten bolt until it strips, then back off a quarter turn.
(humor)
  • Curt Schulze
08 Nov 2018 13:25 #35923 by Curt Schulze
Replied by Curt Schulze on topic Flywheel torque specs
Good point Mike.
  • mikespeed35
08 Nov 2018 04:07 #35920 by mikespeed35
If you eliminate lock washers for Loctite products you may end up with bolts that are too long and bottom out or interfere with something else. If you want to use Loctite go ahead. but use lock washers too if called for.
  • Curt Schulze
07 Nov 2018 19:04 #35919 by Curt Schulze
Mark, you will not find any torque specs for anything in the technical bulletins. Torque wrenches were not available until WWII
The book calls for lock washers , use new ones.
  • ilikescars
07 Nov 2018 14:48 #35918 by ilikescars
Flywheel torque specs was created by ilikescars
I believe the torque for flywheel bolts should be 60 ft lbs, but I'm not sure. Also, the parts book calls for lock washers, but thread locker might be a better idea for this. Looking for other people's experience
