Ignition wire terminals
09 Feb 2019 14:59 #36614
by ilikescars
Ignition wire terminals was created by ilikescars
I had my 35 Auburn cabriolet judged last year at the Sept Auburn meet. One small item was pointed out to me for which I was unaware:
The metal terminal ends on my ignition wires were incorrect: (My wires came from Rhode Island Wire) The wires had 1 inch long terminal ends
that were 1/4" exposed above the brass spark plug receptacles. I was told the solution was to remove those metal ends and replace them with smaller brass clip ends, Motorcraft 5301. I don't believe I received a deduction for this, but I changed them anyway.
The following user(s) said Thank You: 1748 S, johnmereness
