- DavidK
- WinAuBurn
Despite our request the pump was not repaired with modern seals, just repacked. After taking the car for a test drive we had a pool of water and dripping pump. It’s a shame as the test went well otherwise – 15 miles our longest distance yet, good power, strong & even braking, responsive steering, good oil pressure and cooling (despite the leaking pump), 59mph top speed (GPS verified) with a little more to come if we needed it.
There’s certainly more tuning work to be done, but if we can’t get the water pump solved then it will all be for nought at least for the Joplin rally.
Checked our fan pulley and it’s already fitted with a sealed bearing. Phew.
- Brad Hoskins
- Thank you received: 11
Curt Schulze wrote: Also there is a fix for the fan bearing adjustment assembly. Many original 31-32 & maybe 33 had a tendency to come loose and hit the radiator.
Can you share the fix or point to a newsletter article? I've already converted the fan hub to sealed bearings if that is the fix.
Thx
Brad
31 8-98 cabriolet
- WinAuBurn
Curt, We'll look in to that - thank you. We are going through every single nut and bolt on the car. The radiator looks new, I would hate to damage it.
- WinAuBurn
While we were in the area, tested voltage from our generator and got a rather weak 6.85V idle, and 6.4V under load (headlights), battery reads about 6.2- 6.3V with everything off. Seems to be on the low side if we have all the electrics running and may drain the battery.
Since our purpose is to rally the car, we need better lighting. Anything we do has to be removeable so we can easily get the car back to original. The original headlights only offer 21 candle power, we can go up on the cp rating to 32/50 but these draw 3.9A/5.7A each, there are some 6V halogen bulb improvements available but they will also tax the generator with their current draw, even the 25W (4.2A) /35W (5.8A) bulbs are just too greedy for a hot 9A – 12A system. We don’t want to change out the water pump/ generator combo for an alternator and get in to all the wiring issues, besides it will spoil the look.
Not for the purists, but the answer is LED bulbs. However, you try finding a positive earth, 6V, double bayonet, 1930’s fit, hi/low beam LED headlight bulb. They don’t exist, not in the USA at least (or I couldn’t find them). But then I found this place in the UK, co-incidentally where my great uncle used to rebuild vintage motorcycles (no affiliation) www.dynamoregulatorconversions.com/led-headlamp-bulbs-shop.php
The positive earth BA15D 6V double dipper bulbs only draw 0.5A/1.0A, Can’t wait to try them, fingers crossed they may even be a straight fit. Here is a video clip from a happy customer
After staring at the amperage gauge too long, I started to look at the other gauges – Speedo good, Oil pressure good, Temperature good, however, the Telegauges (King Seeley / Hobson) don’t look to have any fluids or if they do it’s gone clear over time. I’d very much like to get these working, on a vintage rally we can’t even back in to miles/gallon to get an estimate of fuel use, the odometer is disconnected and not allowed on the rally. So, have ordered the correct specific gravity green and red fluids and the plan is to disconnect and blow out the capillary tubes from the tank to the dashboard, reseal everything except the open end at the dash board and with empty tanks/pans along with a fine syringe (bird feeders are good) refill the tubes to the correct mark. Am I on the right track or do you have any in-situ pointers for this project?
We had a bit of a setback on the tires, the fitter tells us they were delivered with tubes that have offset stems but our wheels have center set valve stems. After a call to the supplier, was told these tubes don’t exist for 17” 700 tires so they sent what they had. I found center stem tubes from another supplier.
Lastly, you might think us crazy (we do too). We entered the VCRA vintage rally in Joplin Missouri May 16th – 20th, 2018. It’s for a good cause, even if we only get the car to the start line. Burning candle power to get ready.
Colin & Bob.
- WinAuBurn
First up, compression testing found #6 cylinder with little to no pressure – not good, we removed the tappet plate covers and assessed we had a sticking valve. We mixed in 1 quart of ATF with the existing oil, turned it over and let it sit overnight. Voila! In the morning we had pressure back. One of our cylinders is a bit low at 56, a couple are at 74 but we are within 15% +/-. Certainly could be better but acceptable for now.
Next, a carburetor rebuild. After taking it apart I honestly wondered how the car ran at all. Every part was put through the ultrasonic cleaner at least 3 times with a 50:50 mix of Pine Sol and Water. A full service was completed and now the carburetor is pristine. After adjusting the basic settings, time for a trial start up.
Nope. Five seconds running at best. After a few frustrating moments, even checking through the carburetor again, we decided to check our fuel flow. We had previously seen 3.5-4 psi but not measured fuel quantity rate – oops, just a dribble. Hmmm.
The fuel runs through a 6V electric pump near the tank and then through the original mechanical pump. We decided to bypass the mechanical pump and suddenly we had tremendous flow filling a 64oz container in less than 1 minute. So, we directly hooked up the carburetor to the 6V pump. That was it, after making some tuning adjustments with a vacuum gauge connected we had the car running nicely, we’ll make some fine adjustments after going through everything else.
Time for the brakes. We removed all the wheels and hubs, greased the nipples, checked the condition of drums, shoes, assembly and all looks really good (almost new). Decided a road test would help identify any issues best.
So, yesterday we ran the car around Bob’s farm on some pavement and it brought a big smile to our faces. Clutch was smooth, brakes were straight and strong, the engine pulled well through all the gears. We only had the opportunity to run 30mph but this was a pleasing result.
Next week we’ll work on some leaks we need to address. The water pump has a small leak, there’s oil seepage under the car so we’ll get that cleaned up and identify what’s going on, for sure we need a new oil pan gasket set so will get that ordered.
There’s a ton still to do but that’s it for now.
- WinAuBurn
Mike, makes sense. In fact Bob and I discussed that over the weekend and I ordered a compression adapter to work with our cars. If it helps others, the adapter is A-12405-ADP or 28-20987-1 and is commonly used with the Ford Model As of the same era. Hopefully we can get some compression figures later in the week.
- gnutting
Jack Triplett
1931 Auburn 898A speedster
- WinAuBurn
John, I agree it would be good to have an original Schebler or possibly Stromberg carburetor for this engine. Short term, we’ll see if we can get the Carter BB1 (we think 289SD) running with the car so we can test other things. We do have a service kit on it’s way.
Jack, reading about the fire does point one towards an arrestor of some type just for extra security. I’m sure if everything was working correctly it might not be needed. Unfortunately there is little room to fit one it seems.
Curt, thank you, that’s excellent news. We’ll investigate this option for the 2-speed rear. That didn’t take long, I need to find you a bigger challenge!
- gnutting
Jack Triplett
- WinAuBurn
- WinAuBurn
- WinAuBurn
You really won't like it if you forget it. Pull the choke out all the way , as soon as it fires push it in all the way.
- WinAuBurn
- WinAuBurn
- WinAuBurn
- WinAuBurn
Friends installed an overdrive on their 1938 Packard Convertible Sedan and experienced same/similar problems (in their case ate u-joints and had grinding/vibration) - they spent considerable time/money tracking down the issues and I took one look at car on lift and said by shortening the shaft via overdrive they changed the angles and if they put a small taper wedge in under the axle to spring mounts they may solve their problem (aka change angle) - it was a $25.00 issue and an afternoon of labor and they have a couple thousand miles CCCA touring since with no more issues. Sidenote: by changing angle too much you could then cause an oil starvation issue to pinion bearing.
- WinAuBurn
- WinAuBurn
- Brad Hoskins
I was thinking it might be 'cleaner' to put the unit inside the cross member but that would be tough given the width of the cross member.
Some photos from my static display.
The free wheel unit can be unbolted and that would save you about 5" . I would still leave it in place if at all possible .
I did email the ACD Company as per Randy's suggestion to see what they had in the way of NOS gear sets and I think the lowest they have is the 49:11
Anyway you do it, please post some details and photos of your overdrive conversion adventure here !
Brad
31 8-98 cabriolet
- WinAuBurn
After 1934 they were not used in Auburns. The dimension from the back of the 'X' member to the companion flange is 25"
- WinAuBurn
I think you are right. Since Bob and I will not get to see and work on the car until the 2nd week of April, I’m wondering if somebody has time to kindly measure the area from the rear of the X-frame to the rear axle including the freewheel – do we have at least 22” length (O/D is 20”), do we have 4” clearance from the driveshaft centerline to underbody? (O/D diameter is 6.5”).
I don’t see any reason why we could not connect the O/D directly to the rear axle. Also, what is the forum’s thought on the freewheel device? Is it needed, useful? We were not planning on using it.
Thanks, Colin & Bob
- Brad Hoskins
I don't think that the GV overdrive is going to be a problem from a HP perspective. If my read of the literature is correct, The GV at 1:.778 is still a higher (???? I always get confused on which way to call it!) final drive than factory two speed rear end at 1: .666 ( if my math is correct)
The bigger problem might be trying to get the overdrive in there! The free wheel unit already adds considerable length to the transmission and makes for a short driveshaft to start with . Getting drive shaft angles correct could be fun. Did GV say if you could save adding a second driveshaft by bolting up to the tranny or is that just too much hanging off the back?
Feel free to double check my 'speed' math as I was winging it. I used 2300 RPM as that is what Mike suggested and it seemed a pretty reasonable target for these long stroke engines.
BTW Just so you know, I don't think the drive shaft in your car is original to start with so don't get hung up on making changes My understanding is that the originals were a ball and trunnion design. They did not fair well if not perfectly maintained and there are no more parts available , which is why most are now converted to a Spicer joint like yours.
Brad
31 8-98 cabriolet
- WinAuBurn
Mike, please feel free to correct or comment on my summary.
So, the big concern with the GV and probably many overdrive solutions is the longer gearing can be a big step up for the engine to pull. In the GV case it is a ratio of 1:.778, Mike’s practical experience is this was too much for a 45HP car he ran. In addition, Mike had issues with the O/D kicking out downhill. Noted the O/D also does not operate in reverse. Mike’s older unit was 12V only.
We talked again about the Auburn 2-speed axle but it seems finding a ’32-’33 with controls, never mind ensuring it’s integrity is almost impossible. The ‘34+ 2-speed axles are out, too many complications with brakes etc.
On to my call with GV. They now provide a 6V setup for vintage cars like ours, the unit is inline about 20” long and 6 ½” diameter. They do come with standard 8” brackets but those would need to be modified for the X-frame. Also provided is a 2-wire switch for the unit but this could be changed as needed. Losses from the unit while engaged are claimed at 2HP and negligible to zero when disengaged – not too bad, but of course that is nearly 5% on a 45HP car. The O/D stays locked in during uphill or downhill (wonder if Mike’s unit was faulty). Does not operate in reverse gear and should not be operated below 15mph. Price as of writing is $2,995, delivery 3-7 days. Obviously we would need to fabricate new shafts (keep original) and the brackets for the install.
So is 98HP enough to pull the GV O/D in 3rd. Maybe? One thought here is that Auburn introduced the 2-speed axle as an optional upgrade for the ’32-’33 model years but this was still the same 98HP engine on the base car. That’s longer gearing. Also, the steeldraulic brakes remained on the car.
All options considered, we are willing to try the GV solution. Once we have delivery of the car we’ll check all the dimensions before proceeding with the plan. Will keep you informed.
Sorry for the long response, hope it was helpful. Thanks all. And thanks Mike.
- WinAuBurn
- Jonathan Richards
- Thank you received: 24
- Brad Hoskins
Don't get me started on this 'new' forum format and functionality ; it is terrible.!!!
I've had the same thing happen to me (timing out) several times.
I find if you log back in, go the the post you were replying to and , from the 'Action ' menu select 'Reply' again , you will find that you post is still there . As usual, you have to expand the dialog box to see anything.
I never use 'quick reply 'as the functionality is horrible. so I do not know if that works with 'quick reply' or not.
I'd love to see your post!!!!
Brad
31 8-98 cabriolet
CORDiallyMIke
- WinAuBurn
