- Thank you received: 135
8/10 Vapor Lock
08 Jul 2019 14:34 #37706
Replied by 1748 S on topic 8/10 Vapor Lock
Have you noticed the engine running hotter than normal? I know its air cooled but sometimes the belt will loosen up.Then it slips so the fan is not pulling all the air for cooling. The design on this belt is very suspect.It is not running "normally thru the pulleys. It has to twist coming off the crank at the change of direction before it reaches the fan on top of the flat 6 engines. Might even change the belt just because it may not have been changed in a long time. V belts can look fine but are well worn out.
- pneflyer
08 Jul 2019 13:28 #37705
by pneflyer
Replied by pneflyer on topic 8/10 Vapor Lock
Replaced
08 Jul 2019 11:59 #37704
by pete kelly
Replied by pete kelly on topic 8/10 Vapor Lock
SIMPLE QUESTION
DID YOU LOOK FOR A HIDDEN( OR NOT ) FILTER?
PETE
PETE
08 Jul 2019 11:48 #37703
Replied by Curt Schulze on topic 8/10 Vapor Lock
If I were you, I would post this question out on the AACA web site in the 'technical' forum' I would include pix of the engine as it sits in the car.
- pneflyer
08 Jul 2019 02:15 #37702
by pneflyer
Thanks Randy. That is correct 6 cylinder Corvair Corsa engine
08 Jul 2019 01:45 #37701
by RandyEma
Replied by RandyEma on topic 8/10 Vapor Lock
Six cylinder corvair
08 Jul 2019 01:38 #37700
Ca you tell the forum what engine is in this car? I know of three possible engines. Ford, Chevy or Covair.
- pneflyer
07 Jul 2019 23:55 #37699
by pneflyer
8/10 Vapor Lock was created by pneflyer
I purchased #42 8/10 and I am having a vapor lock problem. The car was idle for 20+ years. The gas tank was completely reconditioned with a new coating. I replaced the fuel pump and put new insulator spacers and gaskets between the carbs and the manifolds. The only thing left in my bag of tricks would be to reroute the fuel lines and insulate them. Short of putting a big propeller on the front to force air into the engine compartment, I am open to suggestions. Any thoughts?
Mitch
Mitch
