1936 Auburn Tachometer
- steve pugh
17 Jul 2020 02:40 #40536
by steve pugh
Replied by steve pugh on topic 1936 Auburn Tachometer
I appreciate any help you can provide.
16 Jul 2020 11:44 #40533
by pete kelly
Replied by pete kelly on topic 1936 Auburn Tachometer
Let me check; I should have 1.
Pete
Pete
- steve pugh
16 Jul 2020 05:32 - 16 Jul 2020 05:40 #40530
by steve pugh
Thank you for your suggestion but the piece is stamped steel, it needs to be balanced which it wouldn't be with added material, the shaft needs to be in the true center, and the shaft needs to be at an exact 90 degree angle. I have already shown it to two gauge rebuilding shops and they have said I need to find a new part or a new tach.
Last edit: 16 Jul 2020 05:40 by steve pugh. Reason: add information
- Thank you received: 136
16 Jul 2020 03:05 #40528
Replied by 1748 S on topic 1936 Auburn Tachometer
if this piece broke off the aluminum flat piece maybe some epoxy like JB Weld will repair it. Theres no real twisting torque here. Just a thought...
- steve pugh
15 Jul 2020 17:06 #40527
by steve pugh
1936 Auburn Tachometer was created by steve pugh
The tachometer in my 1936 Auburn died recently. Upon inspection, I found that the stamped metal part that has the needle shaft and spring assembly has broken. Does anyone know where I can get a replacement part or of a repair service that would be able to repair it using a correct original part? Thank you.
