Electric?
- Pwestphal
27 Jul 2020 01:43 #40608
by Pwestphal
Replied by Pwestphal on topic Electric?
Thank you
22 Jul 2020 17:51 - 28 Jul 2020 17:21 #40573
Replied by johnmereness on topic Electric?
Curt's solution is 100% on the money - think bare metal to bare metal contact.
As a sidenote: I had a rebuilt starter and the batter connection was compromised by someone not paying attention when they tightened the bolt for the cable - not enough to disable the car, but just enough to compromise the connection and cause slow turn over.
Last edit: 28 Jul 2020 17:21 by johnmereness.
20 Jul 2020 19:11 #40564
Replied by Curt Schulze on topic Electric?
If after you have cleaned both battery posts and cables, the the frame grounds and the lead washers, the bell-housing where the ground cable mounts, the the starter nose to the starter frame. The problem then lies in the grounding brushes to the front end plate. If that is the case, which it often is, send me an email and I'll send you pictures of the fix. ( am in the club directory.)
- Pwestphal
20 Jul 2020 18:57 #40563
by Pwestphal
Agreed. That is why I’m considering switching back to a 6 volt battery. Easier starting, brighter lights? It would seem that staying with a voltage that the car was designed for makes sense. Thoughts?
20 Jul 2020 18:44 #40562
8V batteries are used to mask a underlying problem. Most commonly poor starter grounding. Find your problem then install a reliable 6V battery.
20 Jul 2020 15:18 #40561
Replied by mikespeed35 on topic Electric?
7.2 Volts will not totally charge a 8V battery!
- Pwestphal
20 Jul 2020 01:14 #40554
by Pwestphal
I measured voltage at generator, output was .20 volts. I cleaned and sanded cutout points and it was reading 7.2 volts. Simple fix. Thank you..
- yorkgulch
- Thank you received: 18
20 Jul 2020 00:54 #40553
by yorkgulch
Auburn 851
Replied by yorkgulch on topic Electric?
The 8 volt batteries are used for easier starting and I think slightly brighter lights. Check to see if generator is charging and how many volts at cutout mounted on generator.
Auburn 851
- Pwestphal
19 Jul 2020 14:46 #40548
by Pwestphal
Electric? was created by Pwestphal
I have a 36 852 SC, I’m new owner. The car came with a 8 volt battery. Question, should I replace with 6 volt? Why did prior owner put in 8 volt? Related issue, the battery drains after a period of driving. Advice please.
