Startix
28 Sep 2020 12:48 #41077
Replied by Curt Schulze on topic Startix
Yes, there is a pin that fits in the slot of the shaft. Don't forget to clean the points.
- Allen
27 Sep 2020 20:30 #41073
by Allen
Replied by Allen on topic Startix
Hi Gary, Here is my picture. My lever is on the post and pivots correctly. The pin that connects it to the groove on the solenoid shaft is missing.
I have latched the lever onto the brass latch by hand. There is no connection to the groove in the solenoid shaft. I am assuming that there is a pin or stirrup of some sorts that connects these two? Thank you. Allen
- Thank you received: 136
27 Sep 2020 13:20 #41068
Replied by 1748 S on topic Startix
In my pictures the lever is riding on the post and it not riveted to anything. Under the plunger there is a very small pin that rides in the plunger brass rings. Good news for you.... I looked once again very closely at your original picture. Your NOT missing the bracket. Its just not riding in the two brass ringed area on the plunger. Now you have to take the plunger and solenoid out to once again get the lever back in the solenoid plunger two brass ringed area.
- Allen
27 Sep 2020 12:49 #41067
by Allen
Hi Gary, Looked at your pictures and the missing piece is still hiding below the spring!!! If your startix turns up might you be able to get a picture if the lost piece please. I was thinking the piece might clip onto the solenoid shaft but in your picture it appears that it might rivet onto the swing arm with a roller that engages in the slot on the solenoid shaft?
29 Aug 2020 19:54 #40812
Sorry but my Startix has been playing hide n seek with me. At this time I can't post a picture but... you can search my posts. I know I showed how to take apart and restore these. You are missing that lever arm.
29 Aug 2020 03:19 #40809
Yes there is a piece missing. I have my Startix opened and will post a picture of it tomorrow.
The following user(s) said Thank You: Allen
- Allen
29 Aug 2020 01:08 #40806
by Allen
Startix was created by Allen
Can someone enlighten me if there is a piece missing from the brass end washer on the lower solenoid shaft circled red? I am thinking there must be something that engages the Relay Plunger Lever (blue arrow) across to the brass latching ramp? I picture would be great? Thank you and stay healthy. Allen
