Can windshield frames interchange between 1931/32 and 1935/36 Speedsters?
09 Sep 2020 11:51 - 09 Sep 2020 22:14 #40921
by pete kelly
Replied by pete kelly on topic Can windshield frames interchange between 1931/32 and 1935/36 Speedsters?
Not interchangeable. The snout on the '31-'33 on the center is longer than the later speedster. The outside pieces will interchange.
Last edit: 09 Sep 2020 22:14 by pete kelly. Reason: wrong info
- Auburn
09 Sep 2020 05:31 - 09 Sep 2020 05:33 #40920
by Auburn
Can windshield frames interchange between 1931/32 and 1935/36 Speedsters? was created by Auburn
Can the windshield frame be interchanged between 1931/32 and 1935/36 Speedsters? They do look the same but are there any differences ?
Thank you.
Rob
Thank you.
Rob
Last edit: 09 Sep 2020 05:33 by Auburn.
