- Thank you received: 219
Cut Out
22 Sep 2020 00:51 #41030
Replied by JIM.OBRIEN on topic Cut Out
What is the spec. on the diode? does anyone have a part number?
21 Sep 2020 17:37 #41029
Replied by Curt Schulze on topic Cut Out
When soldering the diode, NEVER put an open flame on it.
21 Sep 2020 16:28 #41027
by ilikescars
Replied by ilikescars on topic Cut Out
I agree that the diode is the way to go on these
16 Sep 2020 19:29 #40973
The cutout is the source of many burnt up wiring harness. I suggest a diode
replacement. Modern vehicles use them.
16 Sep 2020 15:18 - 16 Sep 2020 15:20 #40971
Replied by johnmereness on topic Cut Out
Perhaps edit title to: Generator 3rd brush adjustment on a X year Auburn if you are seeking higher output - I believe the air gap on the regulator is just a set it and it works or it does not work (ie it is not an adjustment for more power).
Last edit: 16 Sep 2020 15:20 by johnmereness.
- Pwestphal
15 Sep 2020 23:30 #40966
by Pwestphal
Cut Out was created by Pwestphal
What do you know about adjusting the cut out. Air gap? Contact gap? What is best way to test? As I increase RPMs, voltage appears to increase.
