1936 SC dual point distributor wanted.
28 Sep 2020 12:43 #41076
Replied by Curt Schulze on topic 1936 SC dual point distributor wanted.
Yes.
- Allen
27 Sep 2020 22:08 #41074
by Allen
Replied by Allen on topic 1936 SC dual point distributor wanted.
Good evening Curt,
Not to add any advice to this link but for my own understanding of the mechanics of a distributor, am I correct that if the motor is doing 1500 RPM then the distributor will be doing 750 RPM.
Because the distributor weights are spinning, all be it backwards, they will still move out from centrifugal force and adjust the lobe as normal.
But because the distributor is going in reverse then the adjustment from the weights will actually retard the ignition timing?
Do you think this is correct?
Regards, Allen.
Regards, Allen.
27 Sep 2020 14:19 #41069
Since there is no advance, I guess you could say it is mechanical retarded.
- Allen
27 Sep 2020 12:39 #41066
by Allen
Would I be correct to say that you would get a mechanical retarding at 1500?
26 Sep 2020 13:11 #41063
You are absolutely correct Mike.
26 Sep 2020 04:10 #41062
Replied by mikespeed35 on topic 1936 SC dual point distributor wanted.
Goes flat at 1500 because you get no mechanical advance with dist. turning the wrong way. By the way a side note about dist. Just had a friends dist. on sun mach. and installed NOS points. No fire on either set of points. after scratching our heads for a while decided to rubber wheel the contact surfaces of the points and they worked perfectly. Never had that happened before.
25 Sep 2020 19:14 #41061
Funny thing is, It will start right up, but go flat around 1500 RPM.
You really do not need the dual points until the engine revs close to 5 grand. It is all about the advance curve. There is a guy out east that experimented with an IGP4002, and made it run just like an IGH4027. He is out on the AACA board.
25 Sep 2020 16:08 #41056
Replied by johnmereness on topic 1936 SC dual point distributor wanted.
Sidenote: I have seen people try to pick up Cord distributors thinking they will substitute - NOPE, I believe the issue is that a Cord rotates in opposite direction.
24 Sep 2020 13:56 #41046
Paul, you are looking for an Auto-Lite IGH4027
- Pwestphal
24 Sep 2020 11:44 #41045
by Pwestphal
1936 SC dual point distributor wanted. was created by Pwestphal
Wanted: dual point distributor for 1936 super charged engine. My engine currently has single point Auto-Lite.
