851 radiator pads
06 Oct 2020 02:04 #41120
Replied by mikespeed35 on topic 851 radiator pads
Along these same lines. When I had my rad. recored I told the shop to not have the rad. any taller than the orig. rad. They had it 1/4" taller and had to redo. it because it screwed up hood fit. Keep this in mind with rad. work.
05 Oct 2020 13:02 #41113
Replied by Curt Schulze on topic 851 radiator pads
Craig, as John indicated, it is all about fitting the hood. Very often they are a different thickness on either side.
The following user(s) said Thank You: yorkgulch
- yorkgulch
- Thank you received: 18
04 Oct 2020 15:30 #41109
by yorkgulch
Auburn 851
Replied by yorkgulch on topic 851 radiator pads
Thanks John, that's helpful I was wondering if they were thick enough to provide any vibration dampening. I guess not.
Craig
Craig
Auburn 851
04 Oct 2020 15:19 #41108
Replied by johnmereness on topic 851 radiator pads
Mine are of the same material as the body mounts and I believe more thin -- then we had to play with thickness to get nice hood fit. I have no idea what they were originally made of though.
- yorkgulch
04 Oct 2020 15:11 #41107
by yorkgulch
Auburn 851
851 radiator pads was created by yorkgulch
What do the radiator pads between radiator base and frame look like, are they rubber and how thick? They are part no. H1-155 pad core frame not same as body pad/webbing.
Auburn 851
