34 Auburn 8 cyl radiator size
18 Oct 2020 16:14 #41209
Replied by johnmereness on topic 34 Auburn 8 cyl radiator size
I found a 35/36 radiator - that is why the 34 is in the corner of the garage
14 Oct 2020 17:22 #41174
Replied by Curt Schulze on topic 34 Auburn 8 cyl radiator size
Use the 34 core & a 35-36 core support , then lower the bottom mount bracket.
14 Oct 2020 16:30 #41173
by ilikescars
Replied by ilikescars on topic 34 Auburn 8 cyl radiator size
The radiator sheetmetal frame is much wider on a 35-36. Did you cut that down to size?
14 Oct 2020 15:15 #41171
A 34 radiator in a 35/36 - lets just say GRIEF, GRIEF, and more GRIEF until I figured that one out.
12 Oct 2020 17:20 #41158
Thanks Craig ! It has been my experience the 1/2 inch can be taken up in the lower mounting bracket ; albeit it not easily.
- yorkgulch
- Thank you received: 18
12 Oct 2020 17:09 #41157
by yorkgulch
Auburn 851
Replied by yorkgulch on topic 34 Auburn 8 cyl radiator size
I went and measured a 850 and 851 radiators. As Curt said they are very close. Overall height measured at rear center of radiator 850-28 1/2" 851-28" ( they might be slightly taller as there is a little hump in center of top tank. Cores are 850 22 3/4" high 851- 22" high both are 19" wide x 3 1/2" thick. 850 picture attached
Auburn 851
11 Oct 2020 22:29 #41153
Replied by mikespeed35 on topic 34 Auburn 8 cyl radiator size
Before I had the Rad. recored I made a mock up of the size and trial fit the hood. Can save you much grief
CORDiallyMike.
CORDiallyMike.
11 Oct 2020 21:44 #41152
I did that conversion once. I recollect that the width of a 850Y radiator is the same as a 851-2. I was able to alter the lower tank and the mount to the frame. The hood to fit well.
11 Oct 2020 20:28 #41151
by ilikescars
34 Auburn 8 cyl radiator size was created by ilikescars
Anybody know the overall dimensions of a 34 Auburn radiator (8 cyl). The shroud is much narrower than an 851.
Appears to be 26" tall and 18" wide. I have a 36 Auburn radiator, but it is much wider and taller
