Request for Measurements and pictures of radiator - 1932 Auburn – 12 -160A Radia
26 Nov 2020 22:44 #41591
by uconn_1965
Replied by uconn_1965 on topic Request for Measurements and pictures of radiator - 1932 Auburn – 12 -160A Radia
Vintage wings and radiators, great britain
26 Nov 2020 22:38 #41589
Replied by johnmereness on topic Request for Measurements and pictures of radiator - 1932 Auburn – 12 -160A Radia
Curt is 100% on the money there, but I was not aware of the other company.
As to Brassworks, they can get you a close honeycomb, but no 100% cigar on core design - though the chance of having someone there before you though is better than not and they do keep records of how to do things.
26 Nov 2020 21:18 #41588
Replied by Curt Schulze on topic Request for Measurements and pictures of radiator - 1932 Auburn – 12 -160A Radia
There are two radiator suppliers in the UK and one in Australia. Auburn rad cores are unique to Auburn and were not used in any other cars.
26 Nov 2020 17:57 #41585
Worth a try, as building one from scratch is still probably reinventing the wheel as others befor you have had the same problem and ... - only problem will be the pain of prying open your wallet.
- dtitus
26 Nov 2020 16:11 #41583
by dtitus
Replied by dtitus on topic Request for Measurements and pictures of radiator - 1932 Auburn – 12 -160A Radia
Dear John,
Thank you for the references.
I will contact Brassworkes and Corex Honeycombs.
Best wishes.
Diljeet Titus
Best wishes.
Diljeet Titus
25 Nov 2020 20:20 #41569
Or the company in England that makes the "correct correct" honneycombs.
25 Nov 2020 20:19 - 26 Nov 2020 17:55 #41568
Perhaps just have Brassworks make you a radiator - the core may have some thickness differences, but the grill shells are the same, so that tanks are probably adaptable from an 8.
Last edit: 26 Nov 2020 17:55 by johnmereness.
- dtitus
18 Nov 2020 05:51 #41519
by dtitus
Request for Measurements and pictures of radiator - 1932 Auburn – 12 -160A Radia was created by dtitus
Hi Fellow Members,
I am a member of the ACD Club (#2512) and live in Delhi, India.
I own a 1932 Auburn 12-160 Custom Phaeton Sedan. The car is near completion but unfortunately did not come with the original radiator.
I now need to build a new radiator for my 1932 Auburn 12-160 and am looking to source the correct patterns for the top and bottom tanks, side plates, core and all fittings. I would greatly appreciate any assistance with the correct size, dimensions and drawings for the top and bottom tanks, side profiles, fittings and of the radiator core.
I could buy a used 1932 Auburn 12 radiator for pattern and dimensions, if available.
I look forward to hearing from you.
Kind regards,
Diljeet Titus
ACD#2512
Email: [email protected]
Kind regards,
Diljeet Titus
ACD#2512
