8-115 Front hub bearing info
23 Apr 2021 03:53 #42944
Replied by mikespeed35 on topic 8-115 Front hub bearing info
My experience is on most bearings you can use the number on the old bearings and most times they are still available. I know that is the case with L-29. Of course if you don't have the old bearings that's another story.
- joe851
22 Apr 2021 14:17 #42934
by joe851
8-115 Front hub bearing info was created by joe851
Does anyone have the part numbers for modern bearings for the inner and outer hub of a Big 8?
