Loss of Power
- kenswheels
otherwise , you will forget to turn it off. I run the electric pump thru the original Fuel Pump.
- kenswheels
I do have both a regulator and electric pump. What should the regulator be set at? Currently it is at 3.5.
- Red Brick
- kenswheels
- rlwardne
Carb I would check the high speed circuit setup. It’s kind
Of different. Does it blow
Black smoke when this happens? If not it’s more a lean condition by your description. Fuel
Pump maybe failing and need to be rebuilt. I have a V12 where the pump was rebuilt but I believe the cam lobe may be worn and not giving it full stroke.
If I hit the electric pump it will
Really go.
- kenswheels
I have no idea where to start looking.
Ideas?
