- Thank you received: 305
Tech bulletin on setting 852 dual points
01 Sep 2021 07:10 #43827
Replied by Terry Cockerell on topic Tech bulletin on setting 852 dual points
The Canadian border might be opened by then, also the world opened up to international air travel again ........................... we live in hope.
01 Sep 2021 02:09 #43826
by pete kelly
Replied by pete kelly on topic Tech bulletin on setting 852 dual points
Glad to help
SORRY to say I'll miss Auburn again this year.
MAYBE NEXT YEAR
Pete
MAYBE NEXT YEAR
Pete
- Pwestphal
01 Sep 2021 02:00 #43825
by Pwestphal
Replied by Pwestphal on topic Tech bulletin on setting 852 dual points
Mike, thank you. We had to go the any other way. Fact, the flywheel has 110 teeth, so we marked at 27.5 and timed the second set of points. Thanks to Pete. Kelly for old dual point, it needed work, but is in good order now. Thanks to this group, I have my electrical problem fixed. It turns over with 6 volts with not problem. I think we have over heating fixed, but radiator will be pulled this winter. Also, thank s to Curt Schulze for his advice and parts. See you in Auburn!
22 Aug 2021 22:04 #43764
Replied by mikespeed35 on topic Tech bulletin on setting 852 dual points
Sun dist. machine, Best. Points synchronizer, good. Any other way, poor, but can be done. Should be set to open 45 degrees apart.
- Pwestphal
22 Aug 2021 17:42 #43759
by Pwestphal
Tech bulletin on setting 852 dual points was created by Pwestphal
Looking for how to set points on dual point dist? Do I need special tool?
