WTB - 1934-1935-1936 Auburn Phaeton Door Center Pillar Mount Castings
19 Nov 2021 00:00 #44298
Replied by johnmereness on topic WTB - 1934-1935-1936 Auburn Phaeton Door Center Pillar Mount Castings
Thanks, I have the part out to be rercast without screw holes and adapted reproductions to get me through till then. No clue why I have the problem, but 1/32 inch between door and post is a little tight for my liking.
29 Oct 2021 03:47 #44194
Replied by mikespeed35 on topic WTB - 1934-1935-1936 Auburn Phaeton Door Center Pillar Mount Castings
I have made several parts by hand in this way. It takes much time but when parts are not available you do what you have too.
28 Oct 2021 23:47 #44190
by pete kelly
Replied by pete kelly on topic WTB - 1934-1935-1936 Auburn Phaeton Door Center Pillar Mount Castings
Hi John
Perhaps you could grind out a pair from a solid block of brass, steel or whatever easier and faster than finding something to modify.
Pete
Pete
- yorkgulch
- Thank you received: 18
28 Oct 2021 20:32 #44188
by yorkgulch
Auburn 851
Replied by yorkgulch on topic WTB - 1934-1935-1936 Auburn Phaeton Door Center Pillar Mount Castings
Could you put a thicker rubber pad between the b pillar and the bracket?
Auburn 851
28 Oct 2021 20:12 #44187
Replied by Curt Schulze on topic WTB - 1934-1935-1936 Auburn Phaeton Door Center Pillar Mount Castings
John, I think it will be easier to modify the 'B' piller than the bracket.
27 Oct 2021 21:45 - 27 Oct 2021 22:28 #44180
WTB - 1934-1935-1936 Auburn Phaeton Door Center Pillar Mount Castings was created by johnmereness
Does anyone have a set of reproduction door post center mount castings (Brass, Bronze, or Stainless)- I have a 1936 car that for whatever reason is inconsistant with 1935's with allowing use of an original part or a reproduction part (mounting bolt spacing is very different) and need to go back to basics with drilling holes or soldering holes in reproduction and redrilling (ie. both the original and the reproduction mounting brackets cause the reproduction and also original door posts to drag on the top of the doors). I have an upholstery date and not looking good as to time enough to have the part recast.
RE: WTB - 1934-1935-1936 Auburn Phaeton Door Center Pillar Mount Castings
Thanks, John
513-478-1887
[email protected]
Thanks, John
513-478-1887
[email protected]
Last edit: 27 Oct 2021 22:28 by johnmereness.
