1935 Auburn 851 what the correct tire construction type for this car
02 May 2022 00:20 #45319
Replied by Curt Schulze on topic 1935 Auburn 851 what the correct tire construction type for this car
1/8 toe-in , shims can be bought at NAPA.
01 May 2022 17:04 - 04 Jun 2022 19:57 #45313
Replied by johnmereness on topic 1935 Auburn 851 what the correct tire construction type for this car
Radials correct many sins, but get the car right first with the bias ply tires you have on it - needs caster, camber, and toe in checked, as well as must have true rear axel mounting and go down the road straight. Ask around for someone who sets up race cars.
Last edit: 04 Jun 2022 19:57 by johnmereness.
02 Apr 2022 15:27 #45117
Amen Craig. Check toe-in first.
- yorkgulch
- Thank you received: 18
02 Apr 2022 14:41 #45116
by yorkgulch
Auburn 851
Replied by yorkgulch on topic 1935 Auburn 851 what the correct tire construction type for this car
Your 851 originally came with bias ply which don't track quite as well as newer radials. To little toe in could be your problem. If you haven't done it yet check for play in tie rod ends, wheel bearings, steering box. There are also supposed to be caster shims between the springs and axle. That can affect tracking. I had an 851 that was missing them.
Auburn 851
- Darlene Paul
02 Apr 2022 12:14 #45115
by Darlene Paul
1935 Auburn 851 what the correct tire construction type for this car was created by Darlene Paul
My car steers left & right and doesn't track straight. Kurt told me last year
I was using the wrong tire ie: bias ply tires.
However, I forgot which tire construction tire i should use.
Thanks for your input in advance.
Paul Pustay
Paul Pustay
