- Thank you received: 18
Lycoming engine restoration
- yorkgulch
08 May 2022 13:23 #45371
Replied by Curt Schulze on topic Lycoming engine restoration
There was a fellow in SD that bought 8 pistons for a 35 cabriolet . One was too tall , he never got a refund. 15 years ago A lady in the UK was charged over a grand for shipping pistons and valves. No refund.
- Thank you received: 305
08 May 2022 01:35 - 08 May 2022 01:43 #45367
Replied by Terry Cockerell on topic Lycoming engine restoration
It was a disaster dealing with Egge. The first set of pistons had the gudgeon pin holes in the wrong location being lower down 1/4". The heads could NOT be fitted.
The second set of pistons had loose gudgeon pins and had to be replaced with oversize pins. No apologies of any kind, business as usual. Egge's quality control and commitment to supplying a good product leaves a lot to be desired.
I would recommend that Egge only supplies the Russian Army, at least the Ukranians would have the benefit.
Last edit: 08 May 2022 01:43 by Terry Cockerell. Reason: Revising text
- Thank you received: 135
08 May 2022 01:10 #45366
Replied by 1748 S on topic Lycoming engine restoration
Egge has had quality control for several years. A fellow member from Australia got a set of pistons for his 810 Cord. They were too tall and hit the heads causing non rotation. Shipping fees and several calls finally Terry got his pistons about 1 year late. They moved locations too. I do not recommend them. Sadly they are maybe 3 miles from my home and shop....
08 May 2022 00:28 #45365
Ross is good ! Egge not so much...... Talk to Frank or Jimmy.
- yorkgulch
07 May 2022 22:03 #45363
by ilikescars
Replied by ilikescars on topic Lycoming engine restoration
Thanks. I did find a place called Total Seal Piston Rings, thanks to John Mereness
07 May 2022 15:18 #45361
You might try Ross Pistons in Ca. I know they make pistons for the Duesenberg.
07 May 2022 14:52 - 07 May 2022 14:58 #45360
by ilikescars
Lycoming engine restoration was created by ilikescars
Anyone know where to source piston rings for Lycoming engines? Trying to save the old pistons. It's an 8 cylinder engine with 3.08" bore...
Last edit: 07 May 2022 14:58 by ilikescars. Reason: Made a mistake
